Mass Diesel 225's vs DDP 5's
Old 05-03-2007, 11:30 AM
Aosipower's Avatar
Cool Mass Diesel 225's vs DDP 5's
Which injector do you guys think is better. Also is the mass diesel a true 225+ horse injector or is it not near that much? Trying to decide which to go with to make the most hp. Thanks alot guys
Old 05-03-2007, 11:42 AM
dzlfarmboy's Avatar
F1 injectors if you wanna go for the most hp
Old 05-03-2007, 11:46 AM
Aosipower's Avatar
I know...but my pockets arnt that deep! DDP5's are like 300 less! and I am looking at a used set of mass 225's.
-side note- anyone interested in scheid 100's if I end up getting new injectors? pm me
Old 05-03-2007, 11:50 AM
Mike D's Avatar
I have deep pockets, just short arms.. I haven't heard anything bad about the Mass injectors.
Old 05-03-2007, 05:20 PM
fiveology's Avatar
I would be interested in your old injectors if you upgrade.
Old 05-03-2007, 06:10 PM
Aosipower's Avatar
pm's sent, thanks for the interest guys!
Old 05-03-2007, 06:26 PM
Registered
blackdiesel's Avatar
if your still running your ho pump, you will not the max out of any injector over ~150-180. you could switch pumps to an hrvp or so pump and get the full potential out of a BIG set of sticks
Old 05-03-2007, 06:38 PM
Aosipower's Avatar
how about with nitrous? planning to use these for track only...
Old 05-03-2007, 06:51 PM
TheBigNasty's Avatar
I don't know about on an H.O. but they run darn good on a friends SO truck. Dead smooth idle and it runs good too. Hasn't had it on a dyno but with just those injectors and a smarty on 9 he pulled about a truck on me.
Old 05-03-2007, 07:54 PM
Aosipower's Avatar
The mass 225's or the DDP5's?
Old 05-03-2007, 08:02 PM
Registered
It's not the air, it's the amount of fuel pumped to the injector, so nos won't help
Old 05-03-2007, 09:20 PM
The Mass 225.
Old 05-03-2007, 09:25 PM
Aosipower's Avatar
The Mass 225.
Do you know if the 225 stands for added rear wheel hp...like is this injector equivalent to an F1 mach 6...i know its probably not as good as the mach 6 but is it equivalent?
Old 05-03-2007, 09:28 PM
My friend never had it on a dyno with the Mass' so I can't really say. All I know is they idled smooth and ran dang good.
Old 05-03-2007, 10:11 PM
Ph4tty's Avatar
New Era has a 200 stick for less than either of the ones you mentioned =P
A 180 stick is about all you can use.
Quick Reply: Mass Diesel 225's vs DDP 5's
