Mark’s Unified Fuel Theory (shocking lack of empirical data, plenty of subjectivity)
Old 11-24-2010, 02:45 PM
mhuppertz's Avatar
As some of you know I just ran 20 gallons of Jet A through my Dodge (with a quart of 2-stroke oil) and have drawn some conclusions.
My truck hardly smoked at all with Jet A as compared to straight K2.
The engine ran noticeably smoother and seemed to have more power, especially in the low end (unverified, but 363K miles of seat time). Another thing I noticed is the head gasket hardly leaked at all, even with 100+ MPH assaults on the speed limit.
Here is the theory part: I believe running K1 (or a mix) is the equivalent to running high octane fuel in a high compression gasser.
K1 burns more slowly than K2, so my truck (with its pump timing on the edge) benefitted the slower burning fuel. I can imagine this affect would be even more noticeable in the heat of the summer.
Also, my mileage did not suffer noticeably.
So extrapolating, I guess that explains the large power increases with water/meth injection on aggressively timed oilers.
I am back on B5 and it’s a drag. Truck stinks again and is running like it always has, noticeably less smooth.
I am going to do a 50-50 mix of K1 and K2 next to see if that gives me the same outcome.
I know this is heresy, but I don’t care!
Old 11-24-2010, 03:37 PM
Received 1,331 Likes on 862 Posts
.....Man that heading had me laughing so hard.....Thanks!!...
Old 11-24-2010, 06:40 PM
Rick 12v CTD's Avatar
what's k1 and k2? and what's Jet A?
kerosene?
Old 11-24-2010, 06:45 PM
mhuppertz's Avatar
kerosene?
Sorry, K2 is diesel, K1 is kerosene, Jet A is very clean kerosene used in aviation.
Old 11-24-2010, 10:42 PM
Mark Nixon's Avatar
I agree, an A+++ on the title.
How is your truck set up, fuelwise?
Mark.
Old 11-24-2010, 10:47 PM
mhuppertz's Avatar
Mark.
I have a piston lift pump and oversized banjo bolts. I also cut my stock fuel pin within millimeters of its life. POD injectors, fuel screw all the way in, and a medium setting on the star wheel. I have the pump advanced as far as I can before it misses.
Old 11-24-2010, 10:54 PM
Mark Nixon's Avatar
That is a boatload of timing.
Do you have the thinnest washers you can run under the PODs, for good measure?
Mark.
Old 11-25-2010, 08:07 AM
mhuppertz's Avatar
Mark.
Yes, but I am considering cleaning the injector bodies and the holes in the head really well and spraying them with copper tack and going washerless.
Old 11-25-2010, 08:24 AM
brainfade's Avatar
I'd be very interested to hear if the injectors seal without the washers. It can only help with the spray pattern/piston bowl issue.
Old 11-25-2010, 08:40 AM
SORTIE's Avatar
you have lost your mind (or come into a LARGE inheritance)
WTH does a gallon of JetA run ya? Lordamighty that's got to be a wallet jolt
here I was thinkin this thread was about aggressive fuel filtering or polishing
Old 11-25-2010, 08:43 AM
mhuppertz's Avatar
One of my clients is a helicopter company. They have to defuel the birds before they bring them into the shop and can't reuse it, so they just dump it in a storage tank and have to pay to have it pumped out. They would rather I use it!
Old 11-25-2010, 08:49 AM
mhuppertz's Avatar
What do you mean exactly? Lost my mind how? Large inheritance why?
Old 11-25-2010, 08:50 AM
ChrisLib's Avatar
FWIW I run .016 washers under my PODs and it hazes pretty much the same as when it had .030`s, MAYBE a bit better. I do have one popping early now so the haze is real bad but I`m working on that ;-). That is a very interesting find regarding the kero, I think it is amazing the various "fuels" these clanky old beasts will run on.
Old 11-26-2010, 09:55 AM
mhuppertz's Avatar
I'll tell you one thing, when they implement mandatory retroactive testing for diesel's here in New Mexico, I'll be running Jet A or Kerosine. Hardly any smoke at all.
Old 11-26-2010, 10:53 AM
loch's Avatar
You guys might want read this.
http://www.thedieselstop.com/forums/...-diesel-62296/
Its not best idea to run kerosene or jet fuel in our trucks.
Quick Reply: Mark’s Unified Fuel Theory (shocking lack of empirical data, plenty of subjectivity)
