Map sensor trouble
Old Aug 3, 2006 | 09:31 AM
polishing_works's Avatar
Map sensor trouble
Hey whats up. I have a 99 24v that im getting the check engine light on. Code says turbo super boost sensor low voltage. I know that is the Map sensor in other words. Anyways the truck will be fine most of the times but sometimes she drags Edit. The turbo will not spool up until I get real high rpms.
I replaced the sensor. My buddy told me some of those trucks had a wiring problem to the map coming from the firewall. Anybody heard of that. Also I didnt check the wastegate yet, Its a banks big head on it thats fairly new. Also would a boost fooler be any good. Thanks alot for helping me out. Justin
Old Aug 3, 2006 | 01:28 PM
zukgod1's Avatar
You need to fill out your sig so we know what if anything is done to your truck.
Sounds like you have done somethnig if you have a Big Head on the turbo, so I would think a boost fooler would be a good thing.
Havnet heard of the wireing problem.
Have you had the code reset? if not your truck is probably in limp mode from over boost and wont fuel.
Hope that helps
dan
Old Aug 3, 2006 | 09:08 PM
dsl kicks gas's Avatar
i was messin with the map sensor and forgot to plug it back in and i couldnt tell any differnce other than the check eng light
it spolled up the same and all. i quess if i unhook the bats. it'll go off. but i dunno
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
