Map sensor
Old Mar 29, 2006 | 01:47 PM
1998dodge's Avatar
Map sensor
Does unhookin your map sensor give any kind of power gain?
Old Mar 29, 2006 | 07:08 PM
dieselrob's Avatar
Not that i know of. All i know is that if you have a fueling box that plugs in to the map sensors you can unplug the stock plug and just leave the fueling box plug in to over ride the signal. All it does is make a bunch of smoke. To Me there is no sop power gain. I dont know what would happen if you unpluged it on a stock truck but i dont think the truck will run very well because it needs imput from that sensor to fuel. With my comp box it shure can put on a smoke show.
Old Mar 29, 2006 | 09:26 PM
high country's Avatar
w/o a boost fooling box unplugging the MAP sensor is good for a CEL.....no power
Old Mar 29, 2006 | 10:23 PM
BigBlue's Avatar
One guy dynoed his comp with the map plugged and unplugged and gained 10 hp and I believe 15 tq on the dyno. That's enough for me to run around with it unplugged.
Old Mar 29, 2006 | 10:28 PM
cummnz4x4pwr's Avatar
you can only do this with the comp box will not work with tst or ez
jake
Old Mar 30, 2006 | 02:23 AM
1998dodge's Avatar
thanks for the help. My truck has some mods it has a edge box,injectors,intake,4''. I heard that if you have your map unhook it hurts your engine?
Old Mar 30, 2006 | 08:16 AM
jeeptjstud's Avatar
I have mine unplugged. As long as you keep an eye on EGT's it wont be a problem.
Old Apr 21, 2007 | 05:18 PM
jlebrun's Avatar
jake
it works with an ez
Old Apr 21, 2007 | 06:00 PM
tweeder_51's Avatar
where is the MAP sensor located? Do you just unplug it?
Old Apr 21, 2007 | 06:02 PM
jlebrun's Avatar
sorry, im pretty sure it dont work on the juice. but its the plug in up by the fuel filter on the block, just unplug it
Old Apr 21, 2007 | 06:18 PM
Big Dblue's Avatar
I hope it works with my box. It is a D-Box. I think made by Edge "the Ez" i think. Only thing is, is that it has a Superchips logo on it and i have never heard of superchip making a box like the ez. I bought it from a guy used.
Old Apr 21, 2007 | 06:20 PM
starkey's Avatar
On a stock truck, if you unplug the MAP, it'll have no power and throw you some codes. Gotta have a box to make it worthwhile
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
