Map Sensor
Old Feb 17, 2008 | 01:01 PM
12valvetom's Avatar
Map Sensor
I was told you can unplug the map sensor on a 24v and make more black smoke? Can you unplug it if you have a chip?
Old Feb 17, 2008 | 02:07 PM
badme's Avatar
Don't know, but it will only take a minute to find out. Unplug it and see. It won't hurt anything, it would be the same result as if the map sensor failed.
Old Feb 17, 2008 | 10:28 PM
BlackCloud#2's Avatar
You can unplug it!!! All it does is tell the computer that there isn't enough fuel for the air and will supply more fuel. Hence the more smoke....but I don't need to do that now with the drag and smarty!!! You can make just about anyone swerve round the black smoke that way!!! (He he he he its hilarious)
Old Feb 18, 2008 | 04:11 PM
babyjoe's Avatar
I have tried it on my 01 twice now, with a power puck and with out.....it won't run worth a ****, no peddle at all and no black smoke.....Sets the check engine light
Old Feb 18, 2008 | 09:06 PM
scottsjeeprolet's Avatar
It will only work with a box that does boost fooling. I ran my Comp with the MAP unplugged and loved the bottom end power. Now with the DDII's it's too smokey with it unplugged.
so if you have a Comp or EZ i know it works. I'm not sure about the other box's.
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
