MAP SENSOR QUESTION
MAP SENSOR QUESTION
I HAD A POOR EXPERIENCE TOWING BETWEEN 4 AND 5000LBS. I COULD NOT EXCEED 65MPH ON ANY HILL. I RAN A SCAN WITH OBD2 AND NOTHING CAME UP. DOES THE OBD2 READ ANY BOOST ISSUES? I ALSO READ A THREAD ON THIS WEBSITE ABOUT AN ADJUSTABLE PRESSURE REGULATOR BEFORE THE BOOST SENSOR. WHERE IS THE BOOST SENSOR LOCATED AND WHERE CAN I GET THE PARTS TO MAKE THIS CHANGE?
Re:MAP SENSOR QUESTION
NOR GAUGES YET. I AM IN THE PROCESS OF SHOPING FOR THEM NOW. I CHECKED THE IAT THIS MORNING AND IT WAS AS CLEAN AS CAN BE. I AM ALSO GOING TO HAVE THE LIFT PUMP LOOKED AT THIS WEEK SINCE IT IS STLL UNDER WARANTY.
DO YO KNOW ANYTHING ABOUT THE ADJUSTABLE PRESSURE GAUGE AS A WAY TO FOOL THE BOOST SENSOR? AND WHERE IS THIS SENSOR?
[quote author=StakeMan link=board=4;threadid=20206;start=0#msg189999 date=1064682054]
Does it have gauges? If so what where the max readings when towing those loads?
[/quote] I SEE THAT YO ARE IN THE DENVER AREA. I TOWED THIS LOAD TO PPIR AND HAD TROUBLE WITH THE NORTH SIDE OF MONUMENT HILL. ASLO HAD TROUBLE ON C-470 NEAR BANDEMERE SPEEDWAY. STILL HAS ME BAFFLED.
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
Booost Almighty
Jan 1, 2006 01:41 PM
