Manual Transmission Removal
Old 04-20-2007, 07:00 PM
ditchdigger's Avatar
Can anyone tell me how to remove the shifter from the trans? I have the old style shifter cover without the four bolts on the cover.
Old 04-20-2007, 07:07 PM
Box5's Avatar
no problem. once u have the shift boots off and u can see where the shifter goes into the trans. All u do is take two screwdrivers and push down on the metal disk retainer thing thats inside the shift tower and around the black shifter and turn it counterclockwise and it will pop up and u can lift the shifter out. here's a pic to help explain..
Old 04-20-2007, 08:00 PM
Thank you. I finally got it off. Now if I could find an easy way to reinstall with a new clutch.
Old 04-20-2007, 09:12 PM
Box5's Avatar
good luck, it just takes patience.
HUNTINNUT
07-27-2013 11:40 AM
Sniper05
12-26-2008 09:17 PM
trik396
06-01-2008 07:04 PM
LockedandLoaded
02-08-2008 06:14 AM
drrv1
06-07-2005 02:32 PM
Quick Reply: Manual Transmission Removal
