Manual Shifter E-Brake Switch Buzzing...
Old Mar 6, 2004 | 09:23 PM
Ben's Avatar
Ben
The **** on my e-brake switch has started buzzing. If I drive with my arm resting on the console and finger just touching **** it doesn't buzz. But, that gets old. I was thinking of a rubber band around it, light enough to where it actuates but tight enough to keep it from buzzing. Any ideas? Thanks in advance.
Ben
Old Mar 6, 2004 | 09:53 PM
torquefan's Avatar
I have seen a few people use the rubber band trick, and it seems to work. Either get one long enough to go around the e-brake **** and the shifter ****, to keep tension on the e-brake ****, or you can get a small o-ring that just goes on the e-brake stem under the ****, to cushion it.
KWKING
Nov 28, 2009 06:29 PM
Maverick2001
Aug 9, 2008 01:23 PM
caper
Aug 19, 2006 11:34 PM
drrv1
Jun 7, 2005 02:32 PM
