Manual high idle for '07
Old 01-07-2008, 07:30 PM
cazman's Avatar
Does the '07 5.9 have the manual high idle feature? I have seen the posts about it and asked the dealer to activate it, but he cannot find anything about it. The high idle works by itself when the outside temp goes down, but it would be useful anyway.
Old 01-07-2008, 07:52 PM
Cummastroker's Avatar
2x4s work great, just need to cut it to the right size
Old 01-07-2008, 07:56 PM
Festus's Avatar
"4 speed" in your sig??
If your truck is a manual, in addition to enabling it on the scanner, you'd have to get a clutch switch installed at the dealer for >$350, or ground out pin #22 on the ECM for <$20 with a part from Cummins. Your choice.
Old 01-07-2008, 09:21 PM
AH64ID's Avatar
Only 4speed offered in 07 was an auto... just need it enabled.
Old 01-07-2008, 10:32 PM
'strokeThis_'07's Avatar
You can get it enabled...if your dealer cant find anything about it take your truck to a different dealer to get it turned on. The automatic high idle goes to about 1100rpm, manual is adjustable up to 1500...I use it every day, very nice feature.
Old 01-08-2008, 10:31 AM
cazman's Avatar
Yes, it is an Auto. I will hammer the dealer again.
Old 01-08-2008, 07:16 PM
cazman's Avatar
Dealer figured it out, thanks.
kicker210
12-02-2009 08:23 AM
jmccart
06-12-2007 02:12 PM
STATELINE
42
11-25-2005 05:05 PM
GBB
01-27-2005 09:48 AM
Patrick Campbell
17
12-02-2003 08:03 AM
Quick Reply: Manual high idle for '07
