Making the Front Level with the Rear?
Old 03-21-2009, 12:49 PM
the496rocket's Avatar
Starting a new thread, cause I acdentally posted in the 3rd gen forum. MY truck currently has a loft on it, It looks like maybe just a 2" lift, was on when I bought it, anyway, The front sits 2" lower than the rear, and I want to level it out. From the looks of it, The rear have 2" block added under the leaf springs, and in the front it looks like a 2 or 3" leveling kit was added above the springs. So I take it using a conventional leveling kit is out of the question, I dont want to remove the rear block and lower the back to level it. What are my options? Will I need new control arms if I make the front any higher? Let me know guys. Thanks
Eric
Old 03-21-2009, 02:17 PM
hotdram's Avatar
Taller springs and shocks with longer stroke. Since it is already lifted, probably will need new control arms if you lift it any higher.
~Rob
Old 03-21-2009, 03:30 PM
fiveology's Avatar
Skyjacker D25 springs should get you pretty close. You would need shocks for 4 inches total lift in the front (D25s plus leveling kit already in place) and control arms for a 4 inch lift. Control arms can be bought from many sources.
Old 03-22-2009, 11:22 AM
Are the control arms adjustable at all? or do you need to buy a certain length based on how high your lift is?
jmccart
06-14-2008 10:29 AM
jmccart
02-18-2008 10:27 AM
jmccart
12-21-2007 06:00 PM
z-rider
06-19-2007 05:15 PM
teckert
06-09-2004 12:34 PM
Quick Reply: Making the Front Level with the Rear?
