Mag hytech Front Diff Cover problem
Old Dec 28, 2007 | 02:13 AM
Torque master's Avatar
Anyone else out there experince Rubbing issues with the Mag Front Diff Cover my Fins have excessive where and breakage, I have a Thuren Fabrication Lift 3.5 inch roughly. I am going to have and take a Di grinder and make it look pretty, and give it more clearence to make sure will not rub it has broken away a few fins and massively rubbed against it in other areas. You kind of figure the Co. that designs it would have taken these issues into consideration upon designing them?
Old Dec 28, 2007 | 10:28 AM
cbrahs's Avatar
I believe Tritont has the same issue but have not heard of any broken fins. The steering linkages are too close if the truck is lifted and the stabilizer is in the way. Tritont has the superlift dual stabilizer and is only able to run 1 shock unless he has a fix for it! Chime in Ty!
Old Dec 28, 2007 | 10:37 AM
tritont's Avatar
nope I don't. I have all three pans and haven't had any issues. The only problem I came across is, you can't use a dual steering stabilizer as the driver side shock hit the pan. I just went with one shock on the passenger side.
After replacing all the front linkage with Don's stuff.... I don't even need a stabilizer period.
Old Dec 28, 2007 | 10:45 AM
rjm022's Avatar
mag-hytec supposedly fixed the problem with their front diff covers- according to them. i called them a few months back and that is what they told me-but i decided to go with the pml covers.
Old Dec 28, 2007 | 11:21 AM
cbrahs's Avatar
Thanks Ty! You sellin the superlift stabilizer?
Old Dec 28, 2007 | 11:29 AM
tritont's Avatar
I suppose I could but, I'm not sure what hardware might be missing. I already sold the driver side shock and what I have is the center bracket and the passenger side shock. Send me a PM if you're interested.
If I were you though.... I'd get a single Fox shock from Thuren or someone that sells it. In fact, I have one that's brand new. I bought it from Don but never installed it cause I don't need it. He's linkage does the job just fine. If you want that one... I'm sure we can work something out.
Old Dec 28, 2007 | 03:15 PM
WUnderwood's Avatar
I have a Kore steering stabilizer with a PML front cover, with stock suspension, and it gets a little close to the cover, about half an inch, but there are no signs of rubbing.
hope this helps
Old Dec 28, 2007 | 03:17 PM
tritont's Avatar
the Mag-Hytec's did have a problem but, it's was a few yrs ago. They've since redesigned them and no one should have any problems. It's gets real close but, no touch :-)
Old Dec 28, 2007 | 10:14 PM
Mag Hytech Front Diff Rubbs Steering Big Time
I have a mild lift Thuren Fabrication 3.5---4.0 inches And I just came back from the Alignment Center 600.00 had to replace Pit man Link And Steering lower Arm Assembly.
I ended up just poping all the Fins potentially in the Way With A hammer, them Di-grinded it down. Still have to paint it now. What a Shitty Design. They offered nothing in return for there Piece of Front Diff
Tori
Dec 10, 2012 01:17 AM
CACalomino
Jun 16, 2007 06:53 AM
dodgezilla04
Jun 7, 2007 03:43 PM
jiMMyCTD
May 19, 2004 03:13 PM
6cylinders
Dec 4, 2003 11:02 AM
