Mag-hytec tranny pan install questions
Hey guys, I am getting ready to install this Mag-hytec tranny 2qt pan and had a few questions.
How much tranny fluid (in addition to the 2qts) do I need to replace?
Can the ATF 3+ be found in local auto parts stores?
Anyone of you guys done this? If so anything I should look out for?
Thanks!!!
Luis
P.S. I am still looking for a diesel mech in Maryland!!!
Thanks!!!
Luis
I think mine was 16 qts, total (I have a Double-Deep Mag Hytec). It's been a while though. You can always return what you don't use, if you haven't broken the seal.
Chris
Chris
4-8 qts drains from a stock pan depending on how long the vehicle is parked before draining and how long it's allowed to drain.
I usually measure how much I drained rather than fool around with the dip stick. An empty anti-freeze jug works great.
One thing to do is make shure the drain plug isn't over torqued from the factory, and use some oil on the o ring so it doesn't stick. My plug was so tight when i went to drain it the first time i didn't think i was going to get it off.
Hey guys, thanks for the info. It turns out I bought the DD or 9 qt pan.
I will be doing the install either tomorrow or Wednesday (depends on which day is warmer
Is there any dificulties I should be watching out for?
Thanks!!!
Luis
Thanks!!!
Luis
With my single deep pan it took about 7 quarts to fill the new pan. I went to the Dodge dealer and picked up two gallons of ATF 3+ but you can get generic at any auto store.
Tighten the bolts in a cross pattern slowly until snug before you tighten completely. Otherwise it was very easy!
All done!!! It was so easy, I had time to install all of my gauges (boost, pyro & tranny temp) and even adjust my idle!!!
It took 10qts of tranny fluid and the only heads up, is if your doing the double deep pan, you will need a "long" T25 star key to tighten up the filter spacer block.
Thanks!!!!
Luis
Thanks!!!!
Luis
EverydayDiesel
11-11-2007 09:33 AM
Christov
25
03-15-2007 08:26 AM
TexasCTD
26
03-14-2005 08:40 AM
kry226
01-22-2005 10:36 AM
