MAD ECM Install
Old Oct 28, 2004 | 06:04 AM
TurboPirate24v's Avatar
MAD ECM Install
For any who have installed a MAD ( Catcher ) ECM...I've heard it's a simple 30 minute or less task...but, I just wanted to get a handle on the steps ( for the record ):
I'm guessing something like the following:
1. Remove the Negative side battery terminals
2. Remove the Fuel Filter Housing
3. Remove the ECM wiring harness
4. Remove the ECM ( Tools Needed ? ) -- I think a 10mm wrench is needed here, but anything else ?
5. Put new ECM in and put things back together
6. Put battery terminals back on
7. Do APPS reset procedure ???
8. Crank and roll...
Any comments on the above would be greatly appreciated ( especially tools needed and anything missing )...
Thanks,
Scott
Old Oct 28, 2004 | 12:26 PM
Battering Ram's Avatar
All you need is a 10mm socket and an allen wrench to remove the wiring harness. You do not need to remove the filter housing... I was able to get to mine without. Looks like your list is pretty much correct.
Horace
Old Oct 28, 2004 | 12:30 PM
Bob Wagner's Avatar
only one change
8. crank and roll and
Old Oct 28, 2004 | 01:21 PM
Thanks Guys...
How's this list:
2. Remove the Fuel Filter Housing ( optional )
4. Remove the ECM ( 10mm wrench and Allen Wrench )
Old Oct 28, 2004 | 06:27 PM
OlBlue's Avatar
3. Remove the ECM wiring harness (4mm allen wrench).
4. Remove the ECM (10mm socket with 1" extension).
White00
Apr 8, 2005 10:48 AM
600 Megawatts
Jan 22, 2005 04:53 PM
FMF MX
45
Oct 19, 2004 08:18 PM
TurboPirate24v
Oct 8, 2004 12:46 PM
Battering Ram
18
Feb 19, 2004 01:03 PM
