Mach 4.5's are installed
Got my Mach 4.5's installed last night. I haven't driven much with them yet, but did a 4th gear romp with Smarty on SW2 and Drag Comp on 5x3, and I noticed more power all the way to redline and tires broke loose. I'll report results after some more seat time.
Anybody want to by some DD3's ?
I went from M1's to M4's and it amazes me how much cleaner they run. The M4's rarely blow black smoke except below 1400 RPM if I stomp the diesel pedal too hard. But there is not any power there anyways. Otherwise the smoke is almost always grey. Ussually just a short spurt of grey after shifts, then once the right boost comes on the exhaust goes clear and I'm gone.
Jim
They seem smokier in the lower rpm's but they clean up pretty good. They pull much harder on the top for sure. I'll post more results in a couple days.
My piston tops and bowls looked real good after running the M 4.5s for many miles and 1/4 runs.. No hard carbon build up at all, could with them clean with a rag.
RonA
09-04-2007 11:09 AM
B.A.Ram
16
05-16-2006 08:10 AM
sway825
12-08-2004 10:21 PM
smittybuilt
01-05-2004 01:42 PM
