View Poll Results: Lukes linc or DT trac bar
Lukes linc
64.71%
DT Trac bar
29.41%
OEM
5.88%
Voters: 17. You may not vote on this poll
Lukes Linc or Dt trac bar?
Well what do you think. I have no lift, I drive mostly on the highway except during hunting season. I'm leaning toward lukes linc because 1. It's cheaper 2. I really dont think i need something as heavey duty as the DT trac bar. I'm Also going to install darrins steering stabilizer. What do you think.
how about the track bar kit from solid steel,the maker of the DSS.i talked with them last week,they said it should be ready this week some time.it uses a track bar off the 03's and a new bracket,cost around $150.00.i am going to call them in the next day or two.that's the one i wan't....
I saw that on there web site. I guess i need to call them and ask them. What's the difference between the 2nd generation and the 3rd generation track bar?
some one have the links to the above stuff I have dt trac bar and I think the steering stabilizer if its the one for 150 bucks but where do I find lukes links?
or solid steel? plus who has ball joint kits heavy duty? tia
http://www.solidsteel.ca/DSS.htm no info on the trackbar though
www.lukeslink.com/
I've installed Luke's on several trucks, cheap, easy, long lasting fix.
www.lukeslink.com/
I went with the DT trac bar and the Darrins aka Solid Steel stabilizer. Very happy with the results. However, I would not hestitate to buy a trac bar set up from Solid Steel. They were great to deal with and I would highly recommend them and their products.
Ive got a L.L. on my truck. Works good I guess. I put it on before I had a problem becuase I had no intentions of betting into a bad situation with the stocker.
The only thing I have noticed is a small shinny spot on my differential cover. It looks like I had some major axle travel and the LL scored it a little. It is starting to rust, so i guess it isnt hitting it all the time. Who knows?
LL is easy to deal with. I had no problems.
I ordered Lukes Link today for all my front end joints, all 5 joints. I'm going to send a check tommorrow for the dss steering stabilizer. Lukes linc gives you a discount for buying all 5.
what about the differential when you use lukes links? I have seen a couple threads on lukes link hitting the diff. cover?
I am either buying lukes just for the trac links for now or get the dt trac bar plus I am getting the steering stabilizer
89dieselkong
02-12-2011 10:06 PM
Shelljerk47
22
05-05-2007 07:04 AM
J_T
02-25-2007 09:03 PM
getblown5.9
46
05-24-2005 08:41 AM
