What lube do I use?
Old 11-29-2011, 10:42 PM
Lyall's Avatar
What lube do I use?
I have a 98 12 valve with a 5 spd stick. What lube do I put in the stick box and how much. I find it sometimes difficult to change gears - won't mesh.
Old 11-30-2011, 10:47 AM
infidel's Avatar
The only long term proven lubes to use are Castrol Syntorq LT(not Syntech) or Amsoil MTG.
5 quarts.
Any other lubes are well proven to eat your syncros.
Sounds like that may be what's already happened because someone used the wrong lube.
Castrol Syntorq is pricey unless you call these guys> http://www.blumenthalmfg.com/ (888) 236-4800
$52 for one gallon and a quart
or you can pay $22/quart at the dealer for Mopar Synthetic Manual Transmission Lubricant, Mopar P/N 4974459
No auto parts stores sell Syntorq but they will sell you something they say will work that doesn't.
Read this> http://quad4x4.com/NV4500FAQ.htm#what
patdaly's Avatar
Castrol Syntorque LT.
Don't play around either, your Synchros will pay the price.
http://www.bobistheoilguy.com/forums...&Number=505707
http://en.wikipedia.org/wiki/New_Ven...0_transmission
Old 12-07-2011, 10:24 AM
sawmill's Avatar
NOT true i have been using some stuff from walmart and have not had one problem 70,000 the 5th gear droped and refilled it with walmart stuff and now has 250,000 towing loads.
Old 12-07-2011, 10:32 AM
infidel's Avatar
Now I know not to believe anything you say here.
There is plenty of evidence to back up the reality that only two lubes work in the NV
Old 12-08-2011, 08:00 AM
patdaly's Avatar
Some stuff from Wal-Mart?
What, cold cream?
Specify some stuff. I have seen GM Synchromesh in the local Wallyworld, perhaps it would suffice as it is also synthetic.
But it ain't cheap either, and if you are going to buy it, might as well get the right stuff.
Old 12-08-2011, 08:05 AM
Andy505's Avatar
My synchros didn't last 5000 miles after I put regular gear oil it. The liquid gold is the only way to go.
Speaking from experience here.
Old 12-08-2011, 06:59 PM
Robert Rausch's Avatar
As I recall, those synchronizers are not brass--they are carbon fiber or something like carbon fiber, and they are very sensitive to the lube used.
mknittle
03-11-2015 10:47 AM
dssimecek
03-10-2008 04:58 PM
OR Mega Cab
17
09-07-2007 04:26 PM
bocuso
27
01-18-2007 12:54 PM
commando
03-16-2003 08:51 PM
Quick Reply: What lube do I use?
