PDA
View Full Version : LSD (Low Sulfur Diesel)
xzaq103
09-17-2008, 09:23 AM
I’m thinking about getting a tank full of LSD. How much trouble can I get into for running this on the street?
How would they even check for it?
CamperAndy
09-17-2008, 09:25 AM
If you can find it there is nothing to prevent you from using it.
infidel
09-17-2008, 10:42 AM
Running LSD is only illegal in engines made after Jan 2007.
Highly doubt there is anyone checking though but it would be self defeating anyways on a newer truck because the LSD can clog up the smog system.
xzaq103
09-17-2008, 10:48 AM
Im going to try and get some. If my mileage is good enough then ill get a tank for the back of my truck and every time im in the town that sells it ill pick some up.
06RAM2500
09-17-2008, 11:13 AM
It isn't illegal, but harmful to anything that has a DPF. You'll be fine running LSD!
dssimecek
09-17-2008, 11:46 AM
For trucks that you show LSD would be better for them IMO.
It can be found. Check truck stops like Flying J, Loves, Pilot, TA, their web sites often will show who still has LSD. We used LSD on out 2002 on the trip from AZ to Houston TX. Found it at trucks stops. You pull in with the 18 wheelers. Some stations don't like it, but so what you are the customer.
Had a Citco here in NW houston I got LSD from untill it was rebranded to Chevron.
xzaq103
09-17-2008, 11:56 AM
Its a flying J that has it
dssimecek
09-17-2008, 12:01 PM
Then go for the LSD at Flying J. I think it is better for the older engines.
GasganoFJ60
09-17-2008, 02:11 PM
I run it any chance I can find it. I do notice about 1mpg better when I run it too. Engine also idles quieter. =D
CButler610
09-18-2008, 09:17 AM
Exactly.... Makes darker smoke too and smells stronger when it burns. Oh, how I miss LSD (the fuel). I wish I could find it here....[verymad] still looking.
xzaq103
09-18-2008, 10:52 AM
well i plan to pick some up this weekend. I will let you guys know how it goes.
hogboy
09-22-2008, 10:23 PM
Would it hurt any 2 put lsd on an 08? N if i did would it hurt any!
infidel
09-23-2008, 10:23 AM
Would it hurt any 2 put lsd on an 08? N if i did would it hurt any!LSD will plug up the smog system (DPF) on any on road engine built after Jan 2007
Scotty
09-23-2008, 07:13 PM
All my smog stuff fell off and I can net just slightly better mpg when towing. Otherwise I have not noticed a huge difference. I get mine at the Flying J in Gary IN. Only 6840 miles before I hit 100K on my 6.7. Nothing major repaired or replaced. Better mpg then my 07 5.9 with the alterations and no power mods.
infidel
09-24-2008, 10:33 AM
Scotty, is there anything electronic that needs to be tricked when the smog stuff falls off?
xzaq103
09-24-2008, 02:53 PM
Well guys I didn’t get a chance to get any last weekend but I plan to this weekend. Ill keep you guys updated.
Scotty that’s the only reason I plan on trying it is for mpg.
hogboy
09-24-2008, 09:55 PM
if the smog stuff were 2 come off would that void my warranty & is there a change in noise?
Scotty
09-24-2008, 10:37 PM
I got a small 'fooler' box that tells the ecm all is well with regards to the DPF.
I could put an Edge box on that clears the codes at start up but the engine light does not bother me. I can clear codes at start up with my code reader and as long as I hit the open road asap...the engine light stays off but once I am idling and slow driving...it comes back on. They are soft codes so the truck stays operable...no limp mode. Well worth it. The exhaust change I did with getting rid of the dpf gave me a real nice tone...not a drone and not loud.
I have no black smoke either. I did get smoke when I had only done the dpf and the PCV. After the EGR fell off...no more smoke. MPG gains were impressive.
Scotty
DBLR
09-25-2008, 10:34 AM
I've read post of people who lost the DPF getting an improvement of 3 mpg in city driving and even more on the hwy when empty.
