LP upgrade
Can order the Walbro set-up with big line kit from this website. Put Walbro in my truck and it has been great. Also by ordering through DTR you help support website.
How much do you want to spend? Vulcan performance has there big line kit for 115 with out a pump it relocates the stock one to the frame rail , Glacier diesel performance has a big line kit with Walbro pusher pump for around 399 and a fass is like 600. I have not seen complants about any of them. Good Luck
A oem carter pump from napa and a big line kit from Vulcan worked pretty good before I went mechanical =P
The line kits can be found here: http://www.vulcanperformance.com/
or Geno's is always good http://www.genosgarage.com/
Lift pump upgrade option are endless. Let your budget, creativity and herd instinct guide you
FASS, Walbro, relocate kits, DIY anywhere from $100 to $600.
-P
-P
Copy and pasted from another post I made.
IMO,
Best option: Helix 2 cam and 12 valve lift pump.
Better option: Glacier Walbro or Fass
Good option: Pusher from BD, Bulldog or build your own with a relay and Holly Blue.
The "Good option" will cost you in the neighborhood of $120 for the make your own to $225 for the BD or Bullydog. The "Better" option $6-800 maybe a little less, not exactly sure. The Best will cost you 2 to 3 hunded more than the Better option.
The "Best option" is a fix it and forget about it with the 12 valve lift pump. Plus you get the benefit of a more air flow through you head and more low end torque. It's a few more $, but it will be the last time you have to think about it.
IMO,
I did the vulcan big line relocate kit and I got the campaign pump from cummins for $63.00 I now run 14-15 at Idle and 9 atWOT with juice set on 5 its great thanks for your help
NJTman
07-04-2012 11:55 PM
LilBigd02
02-28-2007 08:31 PM
