Lower Hot Idle and some symptoms...
Old 07-05-2007, 04:37 PM
HappyCamper's Avatar
I live forty miles south of SLC, UT where I just purchased a condo that I am currently refurbishing.
In running back and forth on the freeway in this hot weather I have noticed some truck behavior. Air is on and is not affected. This only happens when after the truck has been run a while. It used to be an occassional occurance, but now pretty regular with the hotter weather.
  • When I come to a stop, the idle speed falls to a noticably lower than normal level.
  • The voltage drops slightly.
  • The oil pressure drops all the way and the oil sensor light turns on.
When goosed slightly, the pressure and volt return to normal readings. The battery is known good and is under a year old.
Things I need to check are:
  • Get an accurate reading of the voltage.
  • Put a mechanical oil pressure gauge on it to see what the pressure is dropping to.
I am wondering if the voltage regulator on the alternator is starting to fail.
I also may have a bad oil sending unit.
What do you all think?
Old 07-05-2007, 04:41 PM
Pump's hot (and probably a little tired). Nature of the beast, they idle slower when they get hot - but it does get worse as the pump wears. Set it so it idles around 850 cold and you should be able to keep it above 700 hot. If you can't get it to behave with an 850 RPM idle, start saving your pennies for a new pump.
Old 07-05-2007, 04:46 PM
Thanks Wanna...
Bummer, that is one prognosis I wasn't exactly hoping to hear. I guess I need to look at pulling it out. I will set the idle up a little and see if it will last through Aug - I should have a little time then to pull the pump and replace it. Guess that will be a good time to check and do the KDP if not already complete..
Old 07-05-2007, 06:51 PM
MikeThomas's Avatar
Dang! Its 115 here and my truck did the same thing today...idle dropped so low it was cutting out . Hmm, saving for a pump huh. I guess I should ask if there is a "performance" VE out there? If so, what makes it performance.
Old 07-05-2007, 08:47 PM
Fred Swanson's Avatar
Mike, you should be able to raise the idle to over come it in this heat.
whosdunit
02-16-2019 04:07 PM
justagoodolboy
04-24-2009 09:13 AM
Strjock81
16
12-12-2007 09:53 AM
edwinsmith
04-14-2006 03:53 PM
duallydave
08-07-2005 09:38 PM
Quick Reply: Lower Hot Idle and some symptoms...
