Low water temp
Old 09-08-2008, 09:06 PM
5Oclock's Avatar
Low water temp
I'm having trouble getting my water temp over 140 and even into the "normal" range. Even when the outside temp is near 100. My thermostat is new and the system is full with fresh coolant. Could it be that the new thermostat is stuck open? I took the cover off and coolant poured out the block even before I took the thermostat out to see if there was something lodged in it. It looks fine but I'm not sure which way is open or closed.
Old 09-08-2008, 09:16 PM
DTR's Cow Boss
DodgeCowboy's Avatar
Start the truck when its cold and has not been running and let it get up too temp and feel the hose see if you can feel it open when the hot fluid rush though it.
Old 09-08-2008, 09:32 PM
dozer12216's Avatar
Aftermarket stats are natorious for this. Must be two valve type. Recomend Cummins or Dodge part.
Old 09-10-2008, 10:13 PM
opiy2k's Avatar
when my thermostat was stuck open my water temp never went over 160 even on a hot day. i got mine from napa.
MossyOakCTD
19
12-28-2010 09:11 PM
Racing_Joe66
06-12-2007 05:06 AM
jaconst
06-25-2006 10:23 AM
turbox2
02-06-2006 07:44 PM
firesine
11-24-2005 10:58 AM
Quick Reply: Low water temp
