Low RPM shake?? Any Ideas
Old 11-03-2009, 05:46 AM
1stGen72's Avatar
When pulling any weight at all it has a shake from 1000 to 2000 RPM Then after that it clears up. Any one have any ideas.
Old 11-03-2009, 12:53 PM
Jeff in TD's Avatar
This is on a 3rd gen?
I saw a truck that had those symptoms- basically a dead miss most noticable at lower RPM.
The dealer test showed a couple injectors were on the weak side and changed them. That had no effect, so they ran a compression test. Turned out to have dropped a valve seat.
Old 11-03-2009, 02:58 PM
1stGen72's Avatar
Yeah sorry i dint put that. Or I dint up date my info.. It is an 06 5.9 with a 6 speed. It just got a new turbo put on it due to it being junk after 80K and know this. I think you are probly right It clears up after 2000. But till then its pretty bad.
Old 11-03-2009, 05:41 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
I ran into that problem with engine vibration and it turned out the dual mass flywheel was out of balance. Vibration feels like cylinder injector cutting out. I see you have a 6 speed G56 trans, Part number 52104721AE is to be used on 5.9L Diesel applications only. I would also recomend flash to protect your turbo. Engine Off-Idle Speed Limit Feature To Protect Turbocharger When Vehicle Is Not Moving TSB 18-030-07 Have injector performance test and injector kill test to isolate problem. Just to warn you replacing injectors @600each will not cure vibration problem if dual mass is at fault.
JWHenson
04-13-2009 10:52 AM
ric o'shea
03-24-2007 10:50 PM
93 dually
12-20-2005 10:03 PM
fishin fever
02-22-2004 08:32 PM
Quick Reply: Low RPM shake?? Any Ideas
