Low fuel/smoke on bottom end???
i have been chasing this problem for a while now and i cannot seem to pin point it. my truck has very low fueling on the take off/bottom end. i have my drag comp on 5x5 with what is in my sig and it does not put out that much power on bottom. it is really annoying. it use to but not now. it is not the drag comp because it also does it when i put the smarty in. i have no codes. i recently installed a new vp thinking that was the prob. still no fix. infact, the pedal requires more foot to get it to where i want the acceleration at.
I can't speak for the 24 valves but there was a recall on the 12v throttle cable, and they have been know to loosen up over time, not giving you the fuel you once had.
