Low Boost?
Old 07-22-2009, 09:39 PM
randallp84's Avatar
Low Boost?
I recently installed a boost gauge and pyrometer in my truck and so far, no matter what I do, I can't get the boost above 26psi. This is with the Smarty on SW3 and no other mods. Is this normal? I thought these trucks could hit 35psi stock very easily. Am I wrong? EGTs seem reasonable, about 625-675 on level ground at 70mph and it's not real easy to get it to hit 1100 or 1200. What are your thoughts?
Old 07-22-2009, 09:44 PM
SINGLESTACK's Avatar
sounds like you are running out of fuel, my truck would hit 30 psi stock. maybe your lift pump is needing replaced.
Old 07-22-2009, 10:05 PM
randallp84's Avatar
I was thinking the same thing. I didn't notice much difference between SW3 and SW5 on the Smarty when I turned it up today so it could very well be the culprit. It's also not very consistent. Sometimes it will slip the clutch in 5th and 6th and sometimes it won't, no matter how hard I push it. Not that I WANT it to slip the clutch, just seems like it should do it every time. It's still the stock lift pump on the fuel canister and the stock clutch. I've got 82k miles on it, should be ready to go any time.
Old 07-23-2009, 08:54 AM
randallp84's Avatar
Anybody else have any thoughts on this?
Old 07-23-2009, 09:25 AM
cincydiesel's Avatar
Possible wastegate stuck open? I had a problem with my electronic actuator sticking open and causing lost boost. Try clamping off the rubber wastgate hose with visegrips. Then take a small trip around the block to see if the psi comes up.
Old 07-23-2009, 09:36 AM
randallp84's Avatar
Cincydiesel, what kind of boost were you seeing before you clamped off the hose?
Old 07-23-2009, 09:51 AM
Its hard to say.. I run a Edge J/A that provides boost fooling. Before the clamp I was hitting 32 tops and now I'm hitting 40 max. I could tell something was wrong because the turbo didn't sound right and the egt were getting too hot. Now everything is fine with the clamp.. I've had it on for 50,000 miles with no problems.
Old 07-23-2009, 11:32 AM
randallp84's Avatar
My EGTs are fine so i'm not sure if that's the problem.
Old 07-27-2009, 08:31 PM
My second guess would be LP. Those outer tank pumps stink..
Old 07-28-2009, 08:50 AM
randallp84's Avatar
Sounds like a good excuse for an AirDog.
Old 07-28-2009, 08:54 AM
BossHogg's Avatar
I'd clamp that hose man! Not only will it tell you if your wastegate isn't working properly, but it will give you some free pow-a!
Old 08-21-2009, 09:50 PM
randallp84's Avatar
Ok guys, I tried clamping the hose and it didn't make any difference. One thing I did notice, though, was that it stays at 26psi until 2700 or 2800 RPM and then jumps to 28psi until it starts to defuel around 3200 RPM. This is with or without the hose clamped. Any thoughts?
Old 08-21-2009, 11:02 PM
J-man's Avatar
Cincy, I have the same issue with my 06, but it's somewhat random. Sometimes I can make it climb into the high 30's and then the next time I'll be pulling a trailer up a grade and it will get stuck in the 20's while the power drops off and the egt's sky-rocket. So... do you think the vice grip trick will help me? if so, can you explain or show a pic of where to place the grips?
Old 08-23-2009, 09:50 PM
J-man's Avatar
Bump!!!!!
Old 08-24-2009, 05:01 PM
# 1 FAN's Avatar
I have been having the same problem on my 06 with what is in my sign.It will hit 34-35psi then drop to 30.I have the Smarty with the wastegate set to off,so will clamping the hose make a differance for me.
Quick Reply: Low Boost?
