Low boost prob.
Old 11-08-2009, 08:18 PM
RACER47's Avatar
Low boost prob.
I cant seem to get more than 22 lbs. of boost. I do have a boost elbow with the screw turned all the way in, smarty on level 5 but it wont go over 22 lbs.
is this normal?
What should it max out at?
Old 11-10-2009, 07:39 PM
RACER47's Avatar
Anyone...................
Old 11-10-2009, 09:24 PM
Spooler's Avatar
Not sure about an SO engine. Maybe MikeyB will post. He has an HO though.
Old 11-11-2009, 12:17 AM
tryNto's Avatar
did you check for leaks?
I'm hitting 32-33 pretty regularly with whats in my Sig, probably could get a little more...
Try clamping the hose from the elbow completly closed, see if youy get any more Boost...
other then that, not sure...
Old 11-11-2009, 07:16 AM
CRToney's Avatar
Needle nose vise grips on boost line to wastegate and take her for a spin. You can also apply regulated air pressure to see how your wastegate functions. I did this on my truck to see at what psi the rod would start to move and at what pressure it was fully open. With the smarty is should fuel right up to 44psi I believe as that is what the map sensor can read. With my JR on my '03 she do over 35psi. Take the mp8 off and see what happens as it would boost fool I would imagine.
Old 11-11-2009, 11:25 PM
RACER47's Avatar
I need to update my sig. I dont have the mp8 anylonger. Where would i find leaks? I will try clamping the w/g hose and see if that helps
Old 11-12-2009, 01:27 PM
tryNto's Avatar
look for leaks @ the hose to Turbo, hose to IC both sides and hose to Intake Horn. make a soapy water solution and spray all the connections and look for bubbles...
check the bolts on the Intake Horn...
Old 11-12-2009, 09:17 PM
RACER47's Avatar
So what should i see for max boost ? Whats everyone else seeing with this same set-up ?
Old 11-12-2009, 10:38 PM
White Ghost's Avatar
how are you reading the boost?is it a guage off the intake or off the map?
Old 11-13-2009, 11:45 PM
RACER47's Avatar
Off the intake.
I see some guys getting almost 40lbs!!! Is that for real????
Moobesor
02-23-2008 09:57 AM
dropped2500
02-07-2008 07:14 PM
daveg
13
02-01-2008 11:05 PM
93 dually
10-06-2006 10:23 PM
Quick Reply: Low boost prob.
