Low Amps
Old 01-15-2008, 01:56 PM
12valvetom's Avatar
Low Amps
Will to low of amperage burn up a fass 150 because it doesen't run fast enough?
Old 01-15-2008, 06:55 PM
pokapotato's Avatar
Amprege is a measurement of the flow of electricity a device uses when running. The fuel pump will pull a certain amount of amps at a given voltage. A DC motor will run slower or faster depending on the voltage. As an example, on a cold day when you first start the truck, you will hear the transfer pump running faster then slower as the intake heater cycles periodically, until it is done cycling. The grid heater has such a draw on the system that the voltage drops while the heater is cylcing. If your system voltage is at nominal, your pump should run properly. If your voltage is low the pump will run slower but it should't hurt it.
Old 01-15-2008, 09:20 PM
aksparkey01's Avatar
lower voltage means higher amprage. aslong as you have the right wire and right fuse to protect it it should be fine.
pull
11-12-2006 10:58 PM
I PASS GAS
15
03-13-2005 02:53 PM
durasmack
03-07-2005 10:07 PM
royta
37
12-19-2004 02:44 PM
dodgedude361
20
11-11-2004 09:00 AM
Quick Reply: Low Amps
