Loud chirping sound at shutdown
Old 09-15-2009, 03:50 PM
RVPro's Avatar
My truck has always made a loud chirping sound at shutdown.The sound originates from the serp beltdrive.I have heard other trucks make this same sound and I was told by someone that there is a recall/tsb to correct it.
On a possibly related note just recently I have began hearing and visibly observing a chattering when the a/c is on. The chattering stops when the rpms come up. Tensioner? The compressor is only 4 months old.
Old 09-15-2009, 04:03 PM
92'1stGen's Avatar
The chirp is normal, it's a Cummins thing, but it has become less noticeable as the model years have gone by. Can't help with the chattering though, sorry
Old 09-15-2009, 04:21 PM
With age comes the cage
Colo_River_Ram's Avatar
Do a search here and on Geno's garage for belt squeal / chirp. The TSB is for the overrunning alternator pulley. I went through 4 belts in 22k miles until I had the TSB done to mine. I no longer have the Cummins Chirp at shutdown
With the high millage you have you need to check the idler pulley and all components for wear, Put a breaker bar on the idler arm to release the tension and slide the belt off so you can check everything out..
Hope this helps
Old 09-15-2009, 04:27 PM
zuki_dan's Avatar
After 06 model year they installed one way brgs on the alternator pulley to eliminate the belt chirp at shutdown.
The tensioner pulley has also been known to go bad before and make noise, but that would happen all the time while it is running.
Old 09-15-2009, 04:43 PM
cdennyb's Avatar
Location: In Oroville, Ca., same house for past 46 yrs!
Post removed for language.
Old 09-15-2009, 05:40 PM
RVPro's Avatar
I have had my truck for 3 years now and I am used to the sound. The chatter thing is the main issue now. I might look in to the alt pulley just for grins.
Old 09-15-2009, 07:34 PM
hivoltage's Avatar
I have an '07 that has chirpped since day one....It even had a sexy little tag hanging from the dash when I took delivery stating that the chirp was normal...Mine seems to do it when the AC is on...
Old 09-15-2009, 08:16 PM
CaptainKelley's Avatar
Here it is. Normal but fixable.
http://dodgeram.info/tsb/2006/09-004-06.htm
Old 09-16-2009, 09:53 AM
SpitterGuy's Avatar
Mine does this too, but only when the A/C is on when I shut it down. Defrost mode will also cause it to chirp cause it uses the A/C as well. Not a big deal to me tho.
Old 09-16-2009, 12:37 PM
TexasCTD's Avatar
Mine has been doing it since day one....119K now...on the original serpentine belt. (AC off when I stop)
It's a Dodge CTD trademark....you don't want to "stop" it, imo.
Old 09-18-2009, 11:19 PM
dtrkstan's Avatar
I've had it since day one ...look forward to it, if it doesn't happen I wonder what is going wrong. The sound of good compression, the sound of power! Love it.
Old 09-19-2009, 08:20 AM
Mr.mean's Avatar
Put a little belt dressing on your belt. That will stop it for a while.
Old 09-19-2009, 05:19 PM
BibBubba's Avatar
mine does it too, now im starting to get a sqeeky (sp?) noise coming from that area, guess im going to take it in and see about the fix.
sdaly
05-06-2011 04:27 PM
madmax44
06-17-2009 02:18 AM
Euronymous
24
12-13-2007 11:41 PM
craneage2001
11-13-2007 08:56 PM
CobraCTD
06-19-2007 06:09 PM
Quick Reply: Loud chirping sound at shutdown
