Lots of Black Smoke at startup..
Old 11-25-2009, 08:26 PM
JThiessen's Avatar
Over the past six plus months I have been noticing that my truck is smoking more and more at start up. Its dark grey/black in color. Its now to the point where it is a fairly significant amount, and it will continue to smoke at idle until the motor reaches operating temp (it smokes enough that I can see it floating by the truck if I stop at a light). I don't have any of the typical bad injector symptoms such as hard start, rough idle, or any white smoke. I have been noticing that I have a fairly significant bog that occurs when I accelerate hard - it will run hard to about 2000 rpm, then kinda fall on its face. The two may be unrelated, but I'm kinda wondering if my turbo is functioning?? Any thoughts?
Old 11-26-2009, 01:03 PM
rich's Avatar
could be the nozzles going bad, are egt's a little higher then normal
Old 11-26-2009, 02:14 PM
NickBeek's Avatar
Maybe a MAP sensor too. The turbo might explain higher load condition problems, but idle and low speed / load conditions don't require boost so I would look at fuel delivery and / or sensors.
Old 11-26-2009, 03:03 PM
rich's Avatar
the dark smoke is unburnt fuel which could mean dripping nozzles
flyingd
05-22-2015 03:19 PM
notpowerSTROKIN
10-06-2007 02:50 PM
StevenB05
07-05-2005 11:17 AM
tool
01-18-2005 12:53 AM
muddin4fun
07-22-2004 09:11 AM
Quick Reply: Lots of Black Smoke at startup..
