Lost power at 2500 rpm
When i step on the pedel wot, I have plenty of power until I hit 2400~ rpms and then it just stays there for awhile, feels like it backs off alot, until it shifts finally, and then it hits the power again. What could be going on here? Any adjustments? I have a #6 plate, and I have adjusted the valves recently. thanks teddie
I had a feeling someone was going to say that I need a gsk, but it seems to be a problem that did not exsit and now does, is there anything that can aggravate it? thanks for the response,
How is your governer arm?
did you readjust it?
Rick
its a combination of low timing that needs a bump...as well as the stock fuel plate as well as the stock governor springs.....sometimes taking out the slack from ur throttle cable helps alot oto on an older truck and it costs nothing..mine had about 1 inch of play...got under the go pedal , crimped it and immediately had a more responsive pedal and full travel returned...but the governor springs make a huge difference in driveability...absolutely recommend it
randallp84
65
03-11-2009 01:06 PM
skeeter
01-18-2006 03:17 PM
fishin fever
02-22-2004 08:32 PM
