Loss of top end with Donaldson 51"...anyone else?
Old 03-27-2007, 08:35 AM
RedRacer44's Avatar
I installed the Donaldson 51" a few weeks ago....100% satisfied but I do feel like I lost a bit of top end pull. Anyone else notice this after install? Mine does have the small baffle in it and I didnt smash it out....
I only notice this when I'm at cruising speed (65-75 MPH) and I mash the go-pedal. As before, tranny stays in OD and the truck just takes off...but its almost kinda slow to get "wound up" and start pulling.
Its not a real big concern to me...just wondering if anyone else has noticed this?
Thanks for the input!
Old 03-27-2007, 08:37 AM
RedRacer44's Avatar
Oh yeah...I had an Aero 4040L muffler before the Donaldson...which would make sense as I'm sure the Aero "flows" better than the Donaldson...
On a positive note...my EGTs do rise MUCH slower now when I go WOT now which is really nice....
Old 03-27-2007, 08:43 AM
abc4yew's Avatar
With the stock turbo....it will feel different for sure....a little lazy. Spool up is probably a little different. With lots of fueling you will see the full benefit. ks
Old 03-27-2007, 08:51 AM
RedRacer44's Avatar
Yeah, spool up is still good on the bottom end but on top, it does seem to spool just a bit slower than before which is understandable...
No matter to me....being able to talk at a normal tone at 80 MPH again is well worth it...
Old 03-27-2007, 09:13 AM
expressfish's Avatar
thought it was just me, I installed an aero turbine too and felt like I lost some "torque" as in backpressure. Kinda breaths to much and make me get into the pedal more to make it move. Thinking about going back to something more stock like.
Old 03-27-2007, 09:34 AM
RedRacer44's Avatar
I loved my Aero except for the drone when I was towing. I felt like I didnt lose any bottom end torque when I installed it...
I'm talking about losing top end from installing the Donaldson 51" muffler though...not loss of bottom end with the Aero.
Old 03-27-2007, 11:17 AM
MOJO1's Avatar
Were can i get Donaldson 51" muffler? Do they make 5in enlet & outlet? Straight pipe is to LOAD!
Old 03-27-2007, 01:09 PM
prattman's Avatar
Ryder Fleet Products. I ordered Part Number W26 M090535. It's 5 inch inlet/outlet as is a true straight through muffler. I haven't had a chance to install it yet. I'm doing a whole 5 inch exhaust at the same time.
http://www.ryderfleetproducts.com/cg...m.0&oid=128022
Old 03-27-2007, 01:29 PM
cquestad's Avatar
There is zero backpressure change from a 4" straight pipe and a 51" 4" dia donaldson (assuming you got the straigh thru?)...you should not lose top end.
Old 03-27-2007, 02:03 PM
powerstrokin03's Avatar
donalson has tons of straight 5in 5 out. it jsut depends on the Attenuation (dBA) number you want. here is a list of 5" mufflers: M100582, M100807, M100580, M090535, M090074
Old 03-27-2007, 03:24 PM
drodgers's Avatar
Which one of those part numbers you have?
Old 03-27-2007, 03:48 PM
MOJO1's Avatar
What one do i need i want free flow?
powerstrokin03 donalson has tons of straight 5in 5 out. it jsut depends on the Attenuation (dBA) number you want. here is a list of 5" mufflers: M100582, M100807, M100580, M090535, M090074
THANKs
Old 03-27-2007, 03:51 PM
Luvnacumns's Avatar
M090535,
That is the one I have if I remember right... It is awesome!!!!
Shane
Old 03-27-2007, 03:55 PM
prattman's Avatar
Go to Donaldson's website, Everything you want to know about their mufflers, size, flow rates, inlet/outlet sizes etc.
https://dynamic.donaldson.com/webc/W...?section=10194
I picked the M090535 because it's straight through and has one of the best flow rates of all the Donaldson mufflers. -Glen
Old 03-27-2007, 04:19 PM
MOJO1's Avatar
Man that is a LONG MUFFLER 52ins! I guess i should have bought it first saved a ton on pipe O well thats life in the DIESEL LANE
FAST LANE
M090535,
Quick Reply: Loss of top end with Donaldson 51"...anyone else?
