Loss of power suddenly
Old 10-13-2005, 09:15 PM
Motorpool's Avatar
I can start up and go, no problem but then a mile or so down the road doing say 60 the engine quits whether or not the cruise is set, I throw it in neutral and let it coast over to the side and the engine goes back to idle. If I push the accellator it does nothing but idle until it gets tired of doing that which is always not more than a minute or so and then the engine will get RPM and I can go ahead and go. The "check engine" light comes on the first time I lose this power and it stays on all day but after sitting overnight it dosen't come on until I lose power the first time. I went about 600 miles to Lexington this past week and it did this about fifteen or more times on the way there and back. I just had a LP and Injector Pump put on it two weeks ago. Is this a throttle sensor device problem and if so where is it located? 1999 2WD Cummins Many Thanks, Sonny
Old 10-13-2005, 09:29 PM
MadDog01's Avatar
If your check engine light came on there must be some codes. Try turning ignition to on but don't start three times---- on off, on off, leave on the the last time. you should see code in the odometer. I believe it will say something like PCM ---- done Then ECM --- done. If you have codes they will appear before it say's done. Write them down and let us know.
Gary
Old 10-13-2005, 09:35 PM
crobtex's Avatar
It's possibly an APPS problem. It's located underneath the black cover below the dip stick.
This is the resrt procedure: This procedure has shown to help 24 valve ISB engines. It is basically teaching the fly by wire accelerator on these trucks to reread the position of the pedal and it's limits. Most complaints this will help with is poor acceleration, improper shifting, bucking in 5 and 6 speeds. Has been known to increase fuel mileage in some instances.
1. Set parking brake
2. Disconnect negative battery cables on both batteries
3. Turn ignition key to run(to drain any remaining capacitors)
4. Let truck sit for 30 minutes( this is the recommended minimum)
5. Return ignition to OFF position
6. Reconnect both batteries and secure, not a timed event
7. Turn key to run position(not start) and depress accelerator pedal slowly all the way to the floor
8. Allow pedal to return to top position slowly
9. Turn ignition switch OFF
10.Release parking brake
Old 10-13-2005, 09:37 PM
99 cummins's Avatar
99's don't have that self check capability, were still livin in the old days.
Old 10-13-2005, 09:42 PM
MadDog01's Avatar
That stinks! Shows you how much I know! Good luck
Gary
Old 10-13-2005, 09:45 PM
crobtex's Avatar
Gary
You're just used to those + Y2K fancy electronics. We're from the last century.
Old 10-13-2005, 09:47 PM
ozarkcowboy's Avatar
im havin the same problem exept i dont coast to the side i just throw it in nuetral 4 a sec and keep drivin would that persedure help any?
cowboy
Old 10-13-2005, 09:49 PM
crobtex's Avatar
Even if the reset stops it for now, it may just be a temporary fix. Mine got so bad I had to replace it.
Old 10-13-2005, 09:51 PM
crobtex's Avatar
cowboy
Try it. It won't cause any harm.
Old 10-13-2005, 10:02 PM
99 cummins's Avatar
Seems like we go thru fazes on these trucks, when one person starts having problems all the sudden a lot of them start having it. We seem to be getting over the IP problems and now the APPS seems to be the new in thing, gotta be weather or fuel quallity oriented. I'm pretty sure my sensor is giving out on me to.
Old 10-13-2005, 11:51 PM
jrs_dodge_diesel's Avatar
Some of the 99's had the capability.
Old 10-14-2005, 08:58 AM
Motorpool's Avatar
Crobtex,
You said you replaced it, What is "it" I don't know anything about these trucks, remember that!
Sonny
Old 10-14-2005, 10:21 AM
crobtex's Avatar
Originally Posted by Motorpool
Crobtex,
Sonny
I had to replace the whole APPS assembly. About $336 from Cummns Southern Plains. There's also a thread going right now about how to recal the APPS.
Look here: http://www.dieseltrans.com/phpBB/viewtopic.php?t=614
https://www.dieseltruckresource.com/...highlight=apps
RHC
08-12-2019 03:32 PM
tntk9
11-20-2012 07:09 PM
cbrxxtreme
24
07-17-2008 03:30 PM
speedster1858
08-02-2007 06:11 PM
Commatoze
47
12-23-2003 10:22 AM
Quick Reply: Loss of power suddenly
