Loss of boost 2005 CTD
Old 04-11-2011, 01:03 PM
ripster's Avatar
Towing my gooseneck home from an event yesterday, I started losing boost pressure and could hear boost escaping. A quick check under the hood failed to reveal the culprit, so I continued home, taking it very easy on the hills. After about ten minutes, while pulling a gentle hill, the leak stopped and I was able to generate boost. Deciding to test to see if it would do it again, I slowly pressed the pedal. It held boost fine up to 37 lbs and then it started dumping it again and continued to dump it the rest of the way home. After I got completely unload, I took it out for a drive and continued to lose boost. I clicked the key three times to check error codes, but none were displayed. Any suggestions?
For ref, my truck is 2005 CTD with 174K. Only performance mods are BHAF, 4” cat-back and a Quadzilla Xzillaraider box. Normal max boost is approx 42 lbs.
Old 04-11-2011, 06:42 PM
no_6_oh_no's Avatar
Early 05 CAC had plastic end tanks that would seperate then seal when boost dropped. What is th ebuild date of your truck, its on the drivers door or b-pillar.
Old 04-12-2011, 08:26 AM
ripster's Avatar
It's definitely the dreaded plastic intercooler, but no visible flaws. I'm going to pressurize the system tonight and see if I can find the leak.
Old 04-12-2011, 08:52 AM
no_6_oh_no's Avatar
They will seperate on the seams between end tank and tubes, just a small area, and go back together when the pressure drops. Almost impossible to see a flaw. Should be able to see\hear it when pressurized though.
Old 04-12-2011, 03:38 PM
AH64ID's Avatar
That's what happened to mine, it would hold pressure until about 28 then pop and not let me get above 25 until it cooled...
Old 04-12-2011, 05:37 PM
ripster's Avatar
Winner, winner, chicken dinner! You were right, seperated at the seams. Any suggestions on where to get a new one? Factory or aftermarket?
Thanks,
Rip
Old 04-12-2011, 08:26 PM
no_6_oh_no's Avatar
Good question, I would be tempted to look at the after markets and see how much better they are if any for the $$. Depends on what you wan tto do and how much you want to spend.
Old 04-13-2011, 06:47 AM
Pull Dog's Avatar
I was told by someone that these can be re-sealed at a radiator shop depending on if it is broken or just the gasket let go. You may want to try this. From the information in the conversation, these inner coolers are made very similar to a radiator. They have large o-rings on each side where the housing meets the aluminum cooling tubes. These o-rings can lose their seal. I also have heard if the housing is plastic it can crack and there would be no repair. At any rate depending on the cost and how stuffed your wallet is, you may want to consider looking into having this re-sealed if possible.
Old 04-13-2011, 08:51 AM
AH64ID's Avatar
Normally the tabs that hold the plastic to the metal are what fails. Not worth the repair, IMHO.
Old 04-13-2011, 10:32 AM
ripster's Avatar
Ordered a new one through a friend from Banks.
Thanks to all for the help.
Rip
RHC
08-12-2019 03:32 PM
tntk9
11-20-2012 07:09 PM
cbrxxtreme
24
07-17-2008 03:30 PM
BlackJeep
09-29-2005 08:42 AM
shortround
02-05-2005 08:40 AM
Quick Reply: Loss of boost 2005 CTD
