Loose valave seat make noise?
I have a slight rattle (not timing) at very low rpm, more so while in gear with foot on brake and idling up a little.
It seems to be located near backside of engine block. I thought it may be torque converter bolts, but the sound seems located above that but it is hard to tell.
I understand my year cummins has issues with valve seats coming loose. Just curious if -- before they actually fall out -- will it make a rattling noise?
1 Post
no they make a lot of racket, or at least both of mine did sounds like an injector rattle, lay odds its either the number 5 or 6 cylinder is fixxin to give you some problems
Leaky Gasket
08-14-2008 07:17 AM
MmmDieselFumes
07-07-2007 03:07 PM
johnjudge
02-16-2004 07:52 PM
