lOOSE TOWING MIRRORS
Old 02-01-2008, 01:49 AM
BigGameJames's Avatar
Question lOOSE TOWING MIRRORS
i noticed that my mirrors are getting a little lose the other day.
how do i tighten them?
Old 02-01-2008, 02:08 AM
bsj04's Avatar
id like to know also! the plastic started rattling too, a little super glue fixed the rattle but it shakes so bad i can barly see cars sometimes!
Old 02-01-2008, 05:19 AM
homewrecker's Avatar
The only thng I know how to tighten is the base to the door.Remove the screw in the door panel(near the mirror) and pull the panel back,might have to pull a couple of the push fasteners loose to get enough room.There are 3 10mm nuts that hold the mirror in place.A 1/4" drive socket and rachet helps with the limited space.Be carefull not to overtighten,I did on one of my 01's and broke one of the studs out of the mirror.If its loose somewhere other than this I can't help you.The arm has some fancy push on clip that secures it to the base(Bottom or arm there is a removable round plastic insert to gain access)that I still can't figure out how to remove without breaking something.Hope this helps
Old 02-01-2008, 11:58 AM
EDR
EDR's Avatar
I just helped a buddy with a set of the tow mirrors and what homewrecker mentioned is right on.
If it's the mirror glass itself, here's a link to the TSB with the procedure for removing the mirror glass: Trailer Towing Mirror Glass Removal Procedure
FWIW - On my last truck I had mirrors that vibrated a highway speeds, and I had planned to add blocks of foam behind the glass, one on each side, to eliminate the vibration. I never got around to trying it because I didn't know how to get the glass mirror off and didn't want to make it worse.
Good luck.
tswan
06-02-2010 12:14 PM
Leaky Gasket
08-14-2008 07:17 AM
eb290
08-07-2007 11:59 AM
kully560
01-02-2007 05:26 PM
moopa
13
11-06-2002 11:10 AM
Quick Reply: lOOSE TOWING MIRRORS
