loose steering
Old 12-09-2008, 06:06 PM
lvmknsmoke..'s Avatar
loose steering
wat kind of stabilizer can i get or wat can i do about my wondering steering wheel.. its just got to much play
Old 12-09-2008, 10:24 PM
oldblues's Avatar
hi
permanitly cure the problem by installing the ssi bracket and a 03 up track bar !
also do a stearing box adjustment also.
put in urathane sway bar bushings at end liinks and supports .
use 70 - 80 lbs tire psi e rated tires .
your truck will drive better than new !
Old 12-09-2008, 10:31 PM
STate's Avatar
Do a search for Rock Solid Ram Steering, seems alot of members on here have had positive results. I am thinking of trying it myself, as I have the same problem you do.
Old 12-10-2008, 09:28 AM
bob95065's Avatar
I just fixed my steering. I had a lot of slop at the pitman arm so I installed a DSS I bought here: http://www.pscmotorsports.com/sb100-...izer-p-90.html. That took out about 1/2 of the slop.
Next I adjusted the steering box. You can see how to do that here: http://www.dodgeram.org/tech/mods/st...ear/Adjust.htm. The web page shows the adjustments done off the truck but they can be done one the truck. I didn't have a spanner wrench so I found a center punch that fit in the hole and I tapped it gently with a small hammer. When I completed these adjustments my steering felt showroom new.
I will need to rebuild my box soon because I have leaks. I figure the leaks will lubricate my DSS until I do.
HTH
Bob
Old 12-11-2008, 02:03 PM
mandlbarrett's Avatar
HTH
Bob
I have alot of play in my steering also. I crawled under the truck and had the wife rock the steering wheel back and forth and noticed the sector shaft on the steering box rocking a little at the bottom of the box. I can't tell if the steering gear is leaking really or not because the engine breather is blowing right on it. My question is should I worry about just adjusting the box instead of replacing it right now and just install a DSS to take care of the sector shaft movement? My truck has 70k on it right now.
Old 12-11-2008, 07:28 PM
kell's Avatar
How long does it take to do the "Rock Solid" bushing install. Anybody know?
Old 12-11-2008, 09:10 PM
J.Suplanski's Avatar
Talking front end
Had Carli change out everything, and I had a DSS installed later did wonders!
Old 12-12-2008, 07:10 PM
gator_grabber's Avatar
I just installed a RSS bushing a few weeks ago. It took about an hour to install with the steering column still in the truck. If you have anti-lock brakes (as I do), it slows things down. Be sure to lube the steering shaft interface well! There are a few good threads floating around on this.
Leaky Gasket
08-14-2008 07:17 AM
PurdellMGP
08-12-2003 02:19 PM
Cumminsdude
07-07-2003 11:44 PM
Holycack
06-28-2003 10:42 AM
berner
02-09-2003 07:37 PM
Quick Reply: loose steering
