PDA
View Full Version : Looking at gauges
MARKY MARK
11-17-2002, 12:29 AM
Just got my '99 CTD with auto tranny one week ago. After reading all the post about lift pump problems, I think I better look into at least a fuel pressure guage. What other gauges should I get & how hard would they be to install myself. Kinda like the pillar mounts.
Monty
11-17-2002, 08:24 AM
I see in your sig that your rig is "stock so far" :D Do yourself a favor and go ahead and get a pyro and boost gauge if you plan to be adding any fueling enhancements. The boost gauge is pretty simple and straight forward. The pyro does require drilling and tapping your exhaust manifold for pre turbo installation of the thermocouple. Or, you can mount the thermocouple post turbo in the downpipe. This location is "okay" and will get you by, but, expect to see variations in readings as much as 350-400* from what they really are at the inlet of the exhaust housing. If you have the extra money, go ahead and get the tranny temp gauge.
MARKY MARK
11-17-2002, 01:07 PM
Is this a good price &amp; are these the right ones? These are Autometer Ultra-lite guages. Keep in mind I have the little tweeter speekers on the door pillar. They do have a tranny temp gauge that reads from 140-280 degrees if that would be better. I don't tow very much. This is from Summit Racing. <br> <br> <br><br><br><br> <br>ATM-17205 Dodge: 1998-2001 Ram, with speakers, 2 1/16 in. diameter, black, triple gauge, full pillar gauge pod $52.95 $52.95 <br> <br>ATM-4311 2 1/16 in. diameter, 0 to 15 psi, mechanical, Ultra-Lite series, fuel pressure gauge $36.95 $36.95 <br> <br>ATM-4344 2 1/16 in. diameter, 0 to 1,600 degrees F, electrical, Ultra-Lite series, pyrometer kit $115.95 $115.95 <br> <br>ATM-4357 2 1/16 in. diameter, 100 to 250 degrees F, electrical, Ultra-Lite series, transmission temperature gauge $42.95 $42.95 <br> <br> <br> The total is $248.80 <br>
Monty
11-17-2002, 01:11 PM
That sounds look a really good price for the above listed. Just dont forget the boost gauge. ;)
Ryan
11-17-2002, 01:43 PM
The prices look good. BUT I would opt for a 0-30 psi Fuel Pressure guage. I went with a Westach from Geno's. I read 16 psi at Idle. It is not good to continuously peg a guage which could be done with a good lift pump if you only run a 0-15 psi guage. My Pyro and Boost are both Autometer Z series and they matched ggod enough for me to be happy.
AlpineRAM
11-17-2002, 02:41 PM
Ehmmm MarkyMark- did you check the DTR Onlineshop (http://store.dieseltruckresource.com/dodge-diesel) ?<br>On a fast glance i didn't see too much of a difference. <br>If you don't tow too much and plan to bomb I'd go for a boost gauge instead of the tranny temp. (Tranny temp may go somewhere else, maybe with a buzzer for hi temps)<br><br>Just my 2c<br>AlpineRAM
Commatoze
11-17-2002, 04:09 PM
Where's a good place to bring all the sensor wires thru the firewall?<br><br>-Tom-
chuck3
11-17-2002, 04:20 PM
<br>Where's a good place to bring all the sensor wires thru the firewall?<br><br>-Tom-<br><br><br><br> Tom on the Auto's there's a hole where the clutch rod would go thru and it has a rubber cover over it, thats where I ran my fuel press. line.
j
11-17-2002, 05:19 PM
if i had to do over again i would have gotten a fuel pres. gauge instead of a tranny temp gauge. that can be added later and odds are your fuel pump will be first to go. my truck never gets above 170 when towing (tranny temp), so i should have gone with the fuel gauge instead. however if you have the money, fuel pres/ tranny temp/ boost/ pyro all at the same time would be nice and not much more in cost.
Commatoze
11-17-2002, 06:58 PM
<br><br>Where's a good place to bring all the sensor wires thru the firewall?<br><br>-Tom-<br><br><br><br> Tom on the Auto's there's a hole where the clutch rod would go thru and it has a rubber cover over it, thats where I ran my fuel press. line.<br><br><br>Got it. Thanks Chuck.
MARKY MARK
11-24-2002, 11:41 PM
Ok. I think I have decided on the Autometer Ultra-lites which are white faced. 0-60 boost &amp; 0-1600 pyrometer. But they don't have a fuel pressure guage that goes to 30 psi. They have one that goes to 15 psi &amp; to 100 psi. One doesn't go high enough &amp; one goes to high. The only other white face gauge that goes to 30 psi is the Di-Pricol. Are there any others white face fuel pressure gauges(0-30 psi)?
TxDieselKid
11-25-2002, 02:35 AM
<br>The total is $248.80 <br><br> :o :o OH MAN, that is as much as ONE SPA.... :'( [eyecrazy]
MARKY MARK
11-26-2002, 08:11 AM
Anybody? [undecided]
jec3
11-26-2002, 06:02 PM
I think I remember geno's garage having a westach 0-30 in black or white in their catalog. Check out http://www.genosgarage.com and give them a call...<br><br>Jim
