View Full Version : looking for duelly tires but have some ?
06dodgedrw
05-16-2006, 06:58 PM
I want to up grade my tires a little taller and beefier. What is the widest tire I can put in the back with out rubbing on stock rims. I am planning on putting a 3 inch lift at the same time so i was thinking like a 33 or a 35. I have 4.10 gears so its not a big deal. Also where can I find them? thanks
06dodgedrw
05-21-2006, 10:34 AM
any one have an idea?
Stingerpup
05-21-2006, 07:49 PM
I've done this research for my own vehicle, and after many moons, I came up with this. You can run a 285/70-17 but you really have to pay attention to air pressure. If the tires lose too much air they will rub.
Caveat: I don't have these on my truck, this is the result of my research.
STACKED
08-21-2006, 04:30 AM
i had 305s that were 12.5 wide on mine for a while they rubbed it wasn't that bad then i put spacers on it and cured the problem.
Gotlift01
08-21-2006, 08:44 AM
Yeah throw on a wheel spacer in the rear and you'll be fine....... and with a 3" lift you will be able to clear 33"s easily....35's may or may not rub..
~Nick
LanceD
08-23-2006, 05:15 PM
how bout some 37 12.50 SSRs?
http://www.pavementsucks.com/gallery/images/jkgdiesel_1098922104.jpg
06dually
08-23-2006, 07:45 PM
You don't have 4.10's because you can't get a 6-speed with 4.10 gears.
06dodgedrw
09-02-2006, 09:42 PM
well i do have 4.10 gears if you order a truck like i did you can get them because i have them its on my window sticker and on the rear end sticker to ,and my truck only does about 95mph in 6th gear at 3100 rpm.
Ghostjeeper
09-11-2006, 09:09 AM
What size spacer.
I have a 06 2wd and 40,000 miles on the stock tires.
I am running propane. Triple Dog with OUTLOOK And a gear vendors overdrive.
Truck sees a lot of hwy. And some towing. { 32 ft. 5th wheel, 28 ft. goose neck, 14 ft. dump trailer.
What tires would you all recommend and size. And what width spacers.
Thanks:confused:
ridofpwrstroke
10-25-2006, 07:58 PM
Cant order or get a 4.10 ratio for the six speeds on the 06's. I know, I just ordered one. They only come with 3.73's and I dont know why you would want 4.10s for the six speed overdrive.
06dodgedrw
10-26-2006, 10:57 PM
well i have 4.10s in mine from the factory with the g56 tranny. i ordered it and it cam in with them and it doesnt help that between me and my family(aunts uncles friends ect.) have bought'n over 100 cars/trucks from him in the last 30 years i also got 12,000 of my sticker with no trade in. any way the other reason i know it has 4.10s from the factory its has 5k for miles never ever been back to the dealer i was there the morning they backed it off the trailer with 5 other cars/trucks including my 06 4door 3500 DRW6speed sport with 4.10s my work truck and picked up my truck2 hours later and last week i brought it in to my diesel performance shop to have an eaton lsd put in and he wouldnt not order a lsd made for 4.10s we argued for over an hour and he finally took it apart and it had 4.10s from dodge. the hole 4.10s is all who you know. and i am getting tired of people telling me different about it. you can say what you want i know i have 4.10s from dodge and thats all that matters so say what you want cuz it dont matter because your wrong
vBulletin® v3.6.7, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
