how long will a vp last
Old 05-17-2006, 09:35 PM
edy
edy's Avatar
i would like to know how long my pump will it has be a year since i bought the truck i have a good lift pump fuel pressure gauge change fuel filter every 3000 miles run fuel lubricants big fuel line kit just wondering
Old 05-17-2006, 09:45 PM
ds1rider's Avatar
Could last 1 to 200,000 miles... you never know.
Old 05-17-2006, 09:48 PM
Big Deezul's Avatar
My stocker lasted 220k miles! the first replacement lasted less then 2k miles and I am on my 3rd which is running strong (knocks on wood) Watch your pressure...the rest is up to a higher power
Old 05-18-2006, 07:15 AM
bgoodwin's Avatar
153k miles
Original VP
Original LP
Original clutch
Old 05-18-2006, 10:35 AM
storx's Avatar
still the same injection pump and still going... hopely for a long time 194k miles
Old 05-18-2006, 12:18 PM
Ph4tty's Avatar
45k on the original vp44, 100K on the second one before a persistant p0216 code. It never died, but I replaced it with a hrvp and am hoping for another 100k+
Old 05-21-2006, 11:32 PM
baffled's Avatar
I think it can last quite a while if you are careful about maintaining and monitoring the fuel pressure.
Old 05-22-2006, 06:08 AM
JD730's Avatar
81k on my orginal, 3rd lift pump. Just replace with a hrvp and I have an impressive 340 miles on it so far.
Old 05-22-2006, 05:15 PM
phox_mulder's Avatar
4K on my original. (not a typo, 4,000 miles)
52K on the replacement.
Original lift pump.
phox
Old 05-22-2006, 05:31 PM
JD farmboy's Avatar
182,000 miles and still on my original IP and LP, my fuel pressure never drops below 10 psi. Still going strong, knock on wood.
Old 05-22-2006, 10:47 PM
JDGnut's Avatar
JD... Nice avatar... (especially for a Case Tech... haha..)
173K... 2nd LP... seen them 250+...
Old 05-23-2006, 06:27 AM
edy
edy's Avatar
thanks for all the replys i dont want to spend more money on performance stuff and then the vp go out i want to get two more years out of it and then do a p7100 pump conversion
Cumminsdieselboy
03-01-2005 08:30 PM
Tfeore
04-28-2004 07:24 PM
bajatruck
12-22-2003 09:39 PM
Maccandy
10-22-2003 09:24 PM
Quick Reply: how long will a vp last
