PDA
View Full Version : How to locate tdc
Onemoparnut
11-15-2010, 08:11 PM
I am going to be doing a valve adjustment on a pee pump motor this weekend and I was wondering if they have a pin to find tdc like our trucks have with the ve pump. I know this is a second gen question but there is much more knowledge here than there.
dkimmel
11-15-2010, 08:31 PM
Yes the pin is located behind the pump. It is kinda tough to get at.
Onemoparnut
11-15-2010, 08:43 PM
Is it closer to the timing case or the back of the pump?
JBradley500
11-15-2010, 08:51 PM
you can also watch the valves and not mess with the pin if you want. thats how i have been doing it.
IRoss
11-15-2010, 09:31 PM
I have read that the pin is not completly representative of tdc as compared to watching the valves, or ultimately pulling #1 inj. and using a dial..Also the pin is sometimes frozen:cool: and I find the other methods pretty ez..
92smokin blacky
11-15-2010, 10:53 PM
pull the valve covers and watch #1 valves til theyare close to TDC, then put the the pin in, you might have to wiggle the dampner a little bit to get the pin in but it'll be pretty dang close to goin in that way.
KD93
11-16-2010, 06:45 AM
x2.
CaptainChrysler
11-16-2010, 07:27 AM
Here is one way you can do it:
Get motor half way close the TDC. (watch valves) Tighten a valve/ rocker arm down several turns. Slowly turn the motor over until the piston contacts the valve, put a reference mark on the balancer. Now either back the valve off and roll the motor past TDC (between 45-90*) and tighten rocker back down the exact amount as before, OR leave the rocker where it is and roll the motor backwards until it contacts again (a little less than 1 turn). Reference mark the balancer again. Measure between marks, and the middle is TDC. WARNING: Only rotate motor by hand.
Or you can turn motor over until one valve is full open, and adjust the opposite. This way just leads to lots motor turning, but is more fool proof.
Onemoparnut
11-16-2010, 09:11 AM
Thanks for the info everyone I have one more question. How do I tell when I am close to tdc by watching the valves?
JBradley500
11-16-2010, 09:13 AM
I copied and pasted this from the site i use.
"To locate TDC @ #1, watch #6 until it's at crossover (one rocker going up, the other going down at the same time). This is called the "companion cylinder" method. Adjust the proper valves, then rotate the engine over until #6 is at TDC, which means #1 will be at crossover. Gap the intake valves at 0.010" and the exhaust at 0.020."
When at TDC for #1, check: Intake 1, 2, and 4 Exhaust 1, 3, and 5
When at TDC for #6, check: Intake 3, 5, and 6 Exhaust 2, 4, and 6"
CaptainChrysler
11-16-2010, 11:59 AM
I goofed earlier, you roll it back a little less then 1 turn not 2. I edited that.
If you are turning the engine over (in the direction that it runs) and watch for the #1 intake to close, you will be coming up on TDC. You can tighten the valve up and continue turning until it contacts.
If you are just going to set the valves, you don't really have to find exact TDC.
maybe368
11-16-2010, 12:04 PM
That is correct, the valves just have to be completely closed. There are a few degrees on either side of TDC, on the compression stroke, that the valves are completely closed. One way to check is to make sure that the rockers are loose on the valve. This will not work if the valves are too tight and there is no clearance...Mark
maybe368
11-16-2010, 12:12 PM
Thinking about this, if you are not exactly on TDC od #1, thenyou will have to readjust a little for the other valves, for example intakes 1, 2 and four, if you are not on TDC for #1, 2 and four may not be completely closed. just check and turn the engine until there is play in each valve that you are adjusting...Mark
Onemoparnut
11-16-2010, 12:18 PM
Ok I think I got it makes me love my ve pump even more tdc is so easy to find lol.
JBradley500
11-16-2010, 03:23 PM
yeah theres a lot of "base circle" on the cam that you have to adjust on. you dont need to be perfectly degreed at 0.
foxtrot
11-16-2010, 03:34 PM
That pin is a joke. I believe it is plastic and you can shear it right off.
I never could find the dam spot, ended up going to Cummins
CaptainChrysler
11-16-2010, 03:40 PM
There is more to it than if "the valve is completely closed". The valve can be closed, but the cam is not on the base circle. So if you set the lash when not on the actual base circle, the lash will end up too loose.
Normally there is quite a few degrees before and after tdc that both valves are closed. :)
maybe368
11-16-2010, 04:16 PM
Of course you are right, but I was talking about the target piston being reasonably close to TDC, which would definitely put it on the base circle. Also, If you are talking about a single cylinder, there are quite a few degrees, but the farther from TDC that you are, the less likely that the other valves will be on the base..Mark
TRENDZ
11-16-2010, 08:02 PM
Watch for max lift on one valve, and adjust the one next to it. If the intake is at max lift, the exhaust will be on the base circle- and vice versa.
