A little help please
Old 12-02-2003, 10:33 PM
Krink's Avatar
Does anyone know if I can get a TPS for 1998 24 valve form a Cummins dealer? I tried one today and they couldnt come up with a part #. Does anyone have a part # for it. About how much do they sell for?
Thanks for the help.
Old 12-03-2003, 08:04 AM
billg's Avatar
Re:A little help please
That would be 4002066. Here is a link to most common part numbers to our trucks. http://www.dodge-diesel.org/faq/down...&faqnr=112
Hope this helps.
Old 12-03-2003, 05:46 PM
Krink's Avatar
OK I went to a Cummins dealer today with the # from the link above. 4002066 is a Crank or cam sensor and sells for $30.00.
I called Cummins and the guy told me the TPS is a Dodge only part. Is this true?
I went to my Dodge dealer and had the Dodge # looked up it is 53031575AF ans sells for $275.00 and that is buying it through a guy that works their.
Any other help ?
Thanks.
Old 12-03-2003, 10:30 PM
jrs_dodge_diesel's Avatar
It may be a Dodge only part. Let me ask this, you have a automatic tranny right? From what I understand the TPS is only used with automatic trannys so they know when to shift. So it may very well be a Dodge only part.
Old 12-05-2003, 05:26 AM
Alan_Reagan's Avatar
The TPS is used on all 24V engines to control the fuel delivery. The voltage sensed on the throttle position sensor tells the pump how much throttle you are giving. This place says they have them. Give them a call. 1-888-628-3247 for pricing and availability
http://www.engineautoparts.com/dodge...on-sensor.html
Old 12-05-2003, 08:20 AM
Krink's Avatar
OK I just called that place and they told me they dont have them . ??? I told him they were on their site but he said that they are just starting to carry parts for U.S. trucks.
Has any one found one any were else but the Dealer ?
Old 12-05-2003, 09:14 AM
Barney's Avatar
The Throttle Position Sensor on the 12 valve engines was given a fancy name on the 24 Valv-ers. Its the Accelerator Pedal Position Sensor (APPS).
Its item 18 on this drawing.
http://www.dodgeram.org/tech/dsl/mt_...l_sys_comp.htm
Maybe someone can give me a little help here. I think it was about model year '01 when the APPS was relocated inside the cab, below the Go-Pedal? This essentially made all of the throttle signals electrical.
On the earlier 24 Valv-ers, the throttle cable attatched to the bell crank assembly of the APPS. There is also a cruise control cable from the vacuum actuated cruise control servo motor that is located beneath the driver's side battery.
This servo usually had to be replaced if the battery had boiled over very much. So, the newer throttle position encoders located in the cab are a great idea.
Old 12-05-2003, 11:02 AM
Copenhagenjunkie's Avatar
[quote author=Krink link=board=4;threadid=23184;start=0#msg217362 date=1070425981]
[/quote]
Dealer only part. Around $400 :'(
SuperiorRam
03-15-2007 03:10 AM
Mexstan
09-16-2006 05:29 PM
JW3
03-15-2006 08:23 PM
Lary Ellis (Top)
05-21-2003 10:16 AM
Quick Reply: A little help please
