light switch or multi function switch
Old Aug 20, 2009 | 03:28 PM
smokeyram's Avatar
Last night on the way home from work, first time i had turned the lights on in months.
No low beams, high beams wuold come on, but once in a while flickered out.
Once before i sprayed the multi function switch down with cleaner, but want to make sure im chasing the right issue.
should i pull the dash apart to get in tighther with the cleaner?
Old Aug 20, 2009 | 04:31 PM
I'd throw a headlight switch at it.
Old Aug 21, 2009 | 09:14 AM
smokeyram's Avatar
this would be about the 5th one. maybe ill tear it all down this weekend.
Old Aug 21, 2009 | 06:19 PM
After you fix it, put the headlights on relays. You will stop burning switches and the lights will be brighter too.
BIG MEX
May 22, 2010 10:56 PM
Ram of Steel
Sep 16, 2009 06:30 PM
smokeyram
Dec 16, 2008 07:35 PM
CanuckCTD
Sep 25, 2007 06:44 PM
Tsutter
Jan 19, 2007 07:26 PM
