Light smoke after head work
Old 07-13-2006, 05:31 AM
red12valve's Avatar
Unhappy Light smoke after head work
Ever since I got my truck back from oringing, studing, valve job, timing, 4k gsk, etc. it has smoked lighter colored smoke just after starting it and putting it into gear, even when up to temp. It seems to clear up if I get the revs up or get the egt's up. It's doing it more and more and the amount of smoke is getting more and more. It smells like oil smoke, could it be a sticking valve seal or something. It doesn't do it all the time, mostly when there are alot of people looking at my truck. Also it seems to be getting worse the more I use the N20. It started getting noticable worse when I idled the truck up alittle, but it wouldn't idle in gear when I got it back. Any ideas? Any help would be great!
Old 07-13-2006, 10:50 AM
kawi600's Avatar
Maybe a valve seal? did you have these done as well?
Old 07-13-2006, 06:33 PM
thekidfan's Avatar
That was my first thought! Easy to check
Old 07-13-2006, 07:08 PM
red12valve's Avatar
Should be new, the valves and seats were ground so he should have put new seals in. Hopefully this weekend I will have time to look at it.
Old 07-13-2006, 07:49 PM
Sounds like the timing is slipping.
Old 07-13-2006, 08:17 PM
red12valve's Avatar
REALLY? I didn't wanna hear that
smoknblack01
01-12-2013 07:40 AM
whitebuffalo
02-25-2012 12:32 PM
getblown5.9
15
09-09-2006 08:34 PM
bgilbert
01-07-2006 09:21 PM
Quick Reply: Light smoke after head work
