light out on my overhead console
Old 10-27-2008, 10:51 AM
ram 2500's Avatar
On my way home lastnight i notised that the light that is behind the Step and the C/T buttons where out. Does any body know how to fix them????
Old 10-27-2008, 02:57 PM
Foxborough's Avatar
This might help. I downloaded this mostly for replacing the overhead lights but it does have information on removing the overhead.
READING/COURTESY LAMP REPLACEMENT
Disconnect and isolate the battery negative cable.
Remove the reading/courtesy lamp lens. Using a trim stick, gently pry the forward edge of the reading/courtesy lamp lens outward.
Remove the reading/courtesy lamp socket from the overhead console. Rotate the reading/courtesy lamp socket one quarter turn counter clockwise.
Remove the lamp and socket assembly.
Reverse the above procedure to install.
OVERHEAD CONSOLE REMOVAL
Remove the overhead console retaining screws, located in the sunglass storage bin.
Using your fingertips, grasp the sides of the overhead console and pull straight down evenly to disengage the two snap clips at the front of the unit.
Lower the overhead console far enough to access the wire harness connectors.
Disconnect the Electronic Overhead Module and the reading/courtesy lamps electrical connectors.
Remove the overhead console from the vehicle.
Old 10-28-2008, 07:40 AM
ram 2500's Avatar
""Remove the overhead console retaining screws, located in the sunglass storage bin.""
My truck doesn't have a sunglass storage bin
Old 10-28-2008, 09:29 AM
Foxborough's Avatar
I saw that too, I suspect the screws would be in the same area which would be behind the courtesy lamp. I haven't had to take mine apart yet so I really don't know. Well at least I gave you a bump so someone smarter than me can help . One person ,RatlRatl I believe, has done some fantastic posts here, he even did a write up on removing the whole dash and fixing the blend door. You could PM him if you are stuck.
Old 10-28-2008, 10:50 AM
ram 2500's Avatar
thanks i will do that.
RAT_03
07-21-2010 11:33 AM
800rmk
02-17-2010 02:17 AM
matthopp
08-20-2007 03:11 PM
nugirlintexas02
07-28-2007 05:33 PM
montemorris
01-31-2006 09:57 AM
Quick Reply: light out on my overhead console
