Lift/Towing
Old 08-07-2008, 11:00 AM
tmacracin's Avatar
Lift/Towing
I just bought a aluminum 36' race car trailer(7000lbs loaded) and I need to change some stuff to tow properly with it. I'm too close between the trailer and the tops of my box sides. I'm going to lift the trailer up 1.5" but I will need to drop the truck a bit to make it all work. I have a 3" block in the rear but still have the 1.5" rear block that came with the Fabtech kit. My other option is to pull off the 4.5" Fabtech and put on a entry level KORE kit? But I think my tires will be too big with the wheels I run?
Old 08-08-2008, 12:19 AM
tmacracin's Avatar
anyone have some ideas?
Old 08-08-2008, 12:20 AM
tmacracin's Avatar
here is my new trailer
Attached Thumbnails Lift/Towing-chap.jpg
Old 08-08-2008, 09:01 AM
Rednecktastic's Avatar
I'd try lifting the trailer first and see how it goes.
Old 08-08-2008, 03:29 PM
tmacracin's Avatar
I'm going to lift the trailer a bit but I can't go too much or else I can't get my race car loaded
Old 08-08-2008, 04:07 PM
JPR Ram's Avatar
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
How are the springs mounted on the axle of the trailer? If it's a SPUA (SPrings Under Axle), do an "axle flip" and mount it SPOA (SPrings Under Axle). That's what several people with lifted trucks here in SoCal have done to their Weekend Warriors, GearBox, Carlson and other toybox trailers. It should give you anywhere from 3 to 5 inches of trailer lift; all depending on the size of axle tubing and such.
Old 08-08-2008, 06:08 PM
tmacracin's Avatar
I can't lift my trailer because I won't be able to get my race car loaded up. It only has 2" clearence between the oil pan and ground
Old 08-08-2008, 06:18 PM
Can you run it up on 2x4's or do you have an additional flip down ramp attached to the door/ramp?
Old 08-08-2008, 06:23 PM
JPR Ram's Avatar
That's what I was thinking......Maybe some an additional longer ramp (one for each side) to lessen the sharp angles of the heightened main ramp.
Old 08-09-2008, 10:49 AM
tmacracin's Avatar
Yes I just ordered a set of 70" flip style ramps and a 3 1/2" riser for the rubber bumpers on the door to space it up from the ground to get a better loading angle
edonald849
02-22-2009 04:44 PM
GEN_X
01-03-2006 01:39 AM
CumminsDreamin
03-17-2005 03:15 PM
jnilesPDodge
11-08-2004 10:42 PM
Trusty Steed
02-24-2004 07:11 AM
Quick Reply: Lift/Towing
