Lift Pump? When is it Time?
Old 01-20-2010, 10:23 PM
Brendan's Avatar
On a 12 valve, at what point (hp level) do we need to upgrade to an after market fuel system, fass etc... What kind of hp will the stocker handle?
Old 01-23-2010, 08:28 PM
Brendan's Avatar
Any guesses?
Old 01-23-2010, 10:13 PM
bd02dad's Avatar
you won't run out of fuel with the stock mec. pump.
Old 01-24-2010, 11:23 PM
matthais's Avatar
600
Old 01-25-2010, 12:17 AM
partyshortbusdr's Avatar
500
Old 01-25-2010, 07:58 PM
RonA's Avatar
Around 700hp with a 12mm pump mine started dropping the fuel pressure down into the low teens. When i switched to the 13mm pump it drops it down into the low teens with a little over 1/2 throttle. I have a 200gph Fass on a toggle switch that i turn on when i am going to play. The rest of the time I run off just the mechanical pump.My guess would be around 650 or so.
Txwelder
12-18-2023 02:35 PM
gtaj4
18
09-10-2007 10:19 PM
DuaneWKKC
03-17-2006 08:00 AM
Txwelder
05-19-2005 06:10 PM
Quick Reply: Lift Pump? When is it Time?
