lift pump replacement
Old 10-11-2005, 09:45 PM
jrkerns's Avatar
Has anyone ever tried to replace the stock lift pump with a different type(not talking about a FASS or any other high speed one like that)? I don't know much about diesels but i'm sure that there is another type out there that would work better...
Old 10-12-2005, 10:56 AM
RATTLINRAM's Avatar
If you do a search on Lift pumps,,,,,, you will find enough posts to keep you reading for years. Some have tried using Holley and Carter pumps. I had my original replaced under warranty @ 45k and then installed the large -8an SS lines. I'm at 102k now and still have 15psi @ idle. I don't know as though anyone has had any better luck with the other pumps lasting any longer.
Txwelder
12-18-2023 02:35 PM
mstep3
23
07-27-2010 02:22 PM
Txwelder
05-19-2005 06:10 PM
w4xtc
03-14-2004 09:14 AM
AlpineRAM
01-30-2003 03:24 AM
Quick Reply: lift pump replacement
