lift pump probs with a 12v?
Old 01-07-2008, 11:10 PM
12valvesmoke's Avatar
hey my truck was running like crap high egt's like 900 to 1100 and very low boost 5 psi. so i called piers on the go and they said it was my lift pump and so i called the nearest napa and picked one up without thinking hey 12v usually dont have lift pumps probs soooo i spent 170 bucks for seemingly nothing. but i got it put in by JH performance (BADASS! my truck was parked by nick damico's sled puller and another truck that was in diesel power!) JH said that it was probably my fuel filter BUT before they replaced the lift pump and fuel filter it had a tick since i bought it about a second apart and now its gone... so did my truck have a fluke lift pump problem or just a fuel filter problem since i bought it. i keep telling myself i didnt waste the 170 bucks on the lift pump
sorry if this is confusing i dunno how else to say it
Thanks Jared
Old 01-08-2008, 02:13 AM
wcbcruzer's Avatar
A used lift pump can develop a tick with age. I guess it means it was getting worn out so you didn't waste money on a new pump. You don't want to be stranded somewhere. However, i'm not sure how long a pump can last once it starts ticking. I don't think it's critical.
Old 01-08-2008, 11:12 AM
walexa's Avatar
A lift pump with a tick can last a long time, but when they do die you are normally stranded, at least I was. I had about 196K on my truck, original lift pump and the truck just died. There are a couple check valves that are non-replaceable components and if one or both go bad it will not pump fuel.
Mine ticked for the last 60,000 miles or so. Ticking can also come from other things like the overflow valve, from what I understand.
Waylan
Old 01-08-2008, 11:43 AM
95dodgectd's Avatar
my truck has a tick to it but im sure its just the overflow valve, and i change the cheaper things before i move to more expensive thing, cause i don't have the money to be wrong on something with my truck, 1 more reason i bought a 12v vs. 24v i can't afford to have my truck down.
Old 01-08-2008, 01:20 PM
dieseldemon's Avatar
You should have went to cummins for the pump the price has went down $80.00 now I think Didn't sound like a lift pump problem anyway sounds like a leaking intake hose HIGH EGT LOW BOOST
Txwelder
12-18-2023 02:35 PM
Tami
03-24-2009 08:37 PM
SmokenRam
03-20-2008 06:54 PM
Txwelder
05-19-2005 06:10 PM
Diesel-Dan
06-22-2004 08:57 AM
Quick Reply: lift pump probs with a 12v?
