lift pump pressures
Old 11-25-2003, 02:50 PM
williem's Avatar
lift pump pressures
I'm getting 15psi at idle; but only 8psi at 2500 rpm. What should they be?
Old 11-25-2003, 04:35 PM
Palmetto_kid's Avatar
Re:lift pump pressures
sounds avearage to me.
Old 11-25-2003, 05:00 PM
Administrator / Scooter Bum
Shovelhead's Avatar
I see 15 at idle
13 at 2000 rpm cruise
11 at WOT
Old 11-25-2003, 05:17 PM
PHX_ATC's Avatar
15 to 16 at idle
12 at 2000rpm at 70mph
9-10 at full throttle
Old 11-25-2003, 05:50 PM
RATTLINRAM's Avatar
I've got 15 at idle
13-14 @ 2000 rpm cruise
11-12 @ WOT
I think the Wildcat fuel line upgrade really helps my pressures stay up. ;D I used to drop down to around 10psi @ WOT when towing the 5er up long grades in the mountains, even after the new lift pump was put in.
Not a problem now! ;D
Old 11-25-2003, 07:33 PM
j-fox's Avatar
My guess is one of two things--Either you have a fuel filter plugging or a lift pump going to the trash.
I don't think you want it to go below 8 under load and rpm.
This pressure feeds fuel to the injection pump to lube it. A lot of injection pumps die with 0 pressure.
What year you got? 01 and 02 pumps are said to be better than earlier ones.
Old 11-25-2003, 08:37 PM
BigK's Avatar
While I'd watch this pump, or any other, I'd not change it.
8 psi @ 2500 rpm wot is not a problem, yet......
O.T
09-18-2007 12:50 PM
toupee
06-27-2007 04:19 PM
dodgediesel98
09-03-2003 01:32 PM
Push Rod
12-26-2002 03:31 PM
BigBlue
10-16-2002 04:58 PM
Quick Reply: lift pump pressures
