Lift Pump Location
Old 04-22-2006, 01:08 PM
jbevly's Avatar
Lift Pump Location
Where is the original lift pump on a 2001.5?? I had mine changed under warranty and was curious if they replaced it with the intake pump.
Old 04-22-2006, 01:15 PM
nitrousn's Avatar
On the left side of the motor in back and down from the fuel filter housing. Just follow the lines from the filter housing it should lead you to the pump.
Old 04-22-2006, 04:57 PM
johnh's Avatar
lp
where is your "intake pump"?
Old 04-22-2006, 05:19 PM
XJJoe01's Avatar
Look above the starter to see if you have a "lift pump". There is no intake pump on these trucks (at least, not mine! )
If there is nothing there, the dealer relocated the pump into your fuel tank.
Joe
Old 04-23-2006, 09:27 AM
fschiola's Avatar
See if this will be of some help.
Click
59FORD
04-07-2006 12:28 AM
jlipskoc
13
11-09-2005 10:26 PM
Equalizer 2
10-24-2005 09:44 AM
MARKY MARK
12-21-2002 11:04 AM
Quick Reply: Lift Pump Location
