Lift pump failure questions
Old 04-10-2007, 12:55 PM
Wild4kst8's Avatar
OK... i've been trying to install a FP gauge on my truck to monitor the lift pump... i'm connecting to the port on the VP44 & not getting any fuel to flow thru the line... i also removed the schrader valve & still no flow... i even connected another gauge in front of the filter and still no reading... when i bump the starter, i can hear the lift pump cycle for 20 seconds or so... truck runs good and mileage is 16-20 MPG... i also noticed when i changed the fuel filter last month that the canister would not fill up after bumping the starter
is there another way to determine my lift pump is toast? or, am i beating a dead horse?
TIA
Old 04-10-2007, 01:40 PM
PaulDaisy's Avatar
I think you are not seeing pressure because there is no pressure. If you are not getting any fuel flowing out of the VP inlet port (I would use a needle valve to make sure it can be shut off), this is indeed the sign that your VP is sucking its own fuel, hence no pressure on the suction side.
Replace your LP. Its making noise is no evidence of its pumping anything.
-P
Old 04-10-2007, 02:19 PM
Wild4kst8's Avatar
yeah, i have a valve at the end of the line (in the engine bay)... that's what i was afraid of...
daisy, your sig shows you switched to a Walbro setup with insurance guages... how do you like your Walbro?
anyone have any luck getting these changed out via the Cummins warranty at the dealer? my manual states Cummins starts after the 3/36
Old 04-10-2007, 03:13 PM
CSAGrey1's Avatar
Oh that is a can of worms. By all given rights they should fix it for you but most likely you are going to have to fight for it. Since your VP is not yet dead it would probably be in your best interest to replace the LP yourself with whatever brand/style you choose, as if you do get DC to cover it they are going to insist on the in-tank pump. On that same note if they want to be dinks about it I suppose they could TRY to void the magic 5/100K warranty if you go with a non OEM LP; though you could fight that as well.
First step is to make sure you don't have a bad VP44. If the VP is throwing codes try getting it replaced via the 5/100. One of the things dealerships are famous for is telling you your LP is bad and if they replace it the code for the VP will go away. While this may be the case, the fact remains that if your VP is throwing codes it is a dang good chance the damage has already been done and they are just putting on a band-aid trying to get you past warranty coverage. If it is throwing codes demand a new VP, if it isn't I would save myself the hassle and buy a LP from my local Cummins shop or take the plunge and get an aftermarket kit.
IPDiesel
07-29-2015 09:57 PM
PaulS
09-19-2011 07:39 AM
dodgetrucker75
03-17-2011 09:15 PM
Old & Injecting
08-16-2008 11:27 PM
MARKY MARK
22
12-02-2003 07:43 AM
Quick Reply: Lift pump failure questions
