Lift pump changing tips
Old 11-28-2008, 12:07 PM
leeboy's Avatar
Im about to head out in to the SNOW and attempt to change my stock lift pump with the FASS stock replacement. Any tips for me or is this straight forward? What is bumping the starter to prime mean?Something abot a screen in the instructions also. ( Is 10am to early to start boozin?)
Old 11-28-2008, 01:16 PM
klx650a2's Avatar
Actually 10am is right on schedule!!!
Should be a straight across swap, the screen is a strainer you put inline before the lift pump. Bumping the starter is just that. You hit the starter for just a second but not start the motor, and the lift pump should run for about 25 seconds. Do this a few times to build up fuel pressure and purge the air. If you don't have a fuel pressure gauge, now is a GREAT TIME to get/install one...
Old 11-28-2008, 02:01 PM
hamilton71801's Avatar
Be sure and either blow air back towards the tank or pinch off the line with vise grips because if you don't, you will take a diesel bath and it won't quit coming out.
KRB
12-03-2017 07:58 PM
UnrulyNFS
32
09-08-2008 09:58 AM
UnrulyNFS
11-29-2007 06:29 PM
kawi600
09-04-2006 02:03 PM
MOAGGIE
09-03-2006 07:25 PM
Quick Reply: Lift pump changing tips
